Map Light flickering when revving engine from idle normal?
Old Oct 27, 2009 | 12:24 PM
J37S's Avatar
J37S
i noticed today when i revved my engine from idle... the dome lights flickers... seems like it surges then once u step on the gas.
is this normal?
i have leds for my dome light.
Old Oct 27, 2009 | 12:54 PM
Xcalibur's Avatar
Xcalibur
If that's normal I would be driving the car back to the dealership for a refund.
Take it to dealership and have them fix it ASAP. Should not do that!
Old Oct 27, 2009 | 01:27 PM
J37S's Avatar
J37S
thats what i thought too. its not like it dims bad but it a slight dim barely noticable but its buggin me
Old Oct 27, 2009 | 01:39 PM
demuslee's Avatar
demuslee
Take it back ... sounds electrical and should still be under warranty ... though they may rag on you about the LED dome lights. I'd put back the standard issue bulbs and take it back to infinity.
Old Oct 27, 2009 | 01:49 PM
Xcalibur's Avatar
Xcalibur
Sorry! I didn't read that last line. Take out the LEDs and put back in the incandescent bulbs and test it. If no issues then it's your LEDs.
Old Oct 27, 2009 | 01:52 PM
hispeed-lowdrag's Avatar
hispeed-lowdrag
^+1 test the different bulbs.
where did you buy the led's from? If they are eBay brand I'll just about guarantee it's the bulbs but definitely try the originals before you take it back to the dealership.
Old Oct 27, 2009 | 03:54 PM
J37S's Avatar
J37S
i bought it from this site hidny.com.
its just the led whats doing it... i check the accent light in between the map lights and ITS NOT DIMMING when I rev the engine.
its just the map LED lights doing it. ill try to swap out and see. if its the LEDs only then I guess its normal.
ill take a video today too.
Old Oct 27, 2009 | 06:55 PM
Wezbian's Avatar
Wezbian
My LED's do the same. They are always slightly on even when they are supposed to be off. My sub is what causes the power draw, but before i installed the sub, I noticed with revs the LEDs would flicker.
Old Oct 27, 2009 | 07:29 PM
J37S's Avatar
J37S
did u get it checked?
Old Oct 27, 2009 | 11:21 PM
notsoricer's Avatar
notsoricer
ha, thats funny cuz my headlights flicker when i rev-match my down shifts.
abretz89
Aug 20, 2015 11:58 PM
VIVID
Aug 3, 2015 02:40 PM
