Help Anybody having problems with LEDS?
Old May 2, 2009 | 10:09 AM
pfizzle's Avatar
pfizzle
My liscene plate LED went out twice on me. It would start to flicker then die. Also my door LED is flickering like crazy.
Any ideas?
Old May 2, 2009 | 10:13 AM
Kidcane's Avatar
Kidcane
Florida G Club
My license plate gave me some issues but ended up being a bad connection. One thing I have noticed is my dome lights, if I leave them so that when the doors open they turn on, when the doors are closed and I am driving they are still very dimly lit. You get that?
Old May 2, 2009 | 10:24 AM
aznutx's Avatar
aznutx
yeah i think it's normal for the g
but the only time my led's flicker is at startup other then that they are just solid.
Old May 2, 2009 | 10:32 AM
pfizzle's Avatar
pfizzle
Effin Infiniti. Would it have killed them to add LEDs to their lighting?
Old May 2, 2009 | 11:39 AM
Csquared's Avatar
Csquared
Where did you buy your LEDs? Superbrights dont seem to like to be in places such as the headlight of license plate, mine always die so i got ijdm instead
Old May 2, 2009 | 11:47 AM
pfizzle's Avatar
pfizzle
Superleds.
I think I am going to switch to iJDM
Old May 2, 2009 | 02:27 PM
aznutx's Avatar
aznutx
got mine at superled, worked fine for 1.5yrs+
Old May 2, 2009 | 04:18 PM
ucla bruin's Avatar
ucla bruin
Another guy down in So Cal had the same flickering problem with the door LEDs, it turned out that the connector prongs that hold the LEDs in place was bend so it wasn't making solid contact with the LED. Check the connector and maybe bend it a little with pliers.
Dome LEDs might stay dimly lit when it's supposed to be off because they have very little load and only require very little current, which is always present in the wiring, to stay on. The original filament bulb was a heavier load and required more current to stay lit. You can try using more LED or something of a bigger load to fix the problem. But it's not really a "problem".
__________________
Old May 2, 2009 | 05:00 PM
oOmikeyboy's Avatar
oOmikeyboy
I am having the same problem, in both puddle lights on the doors. I removed them, and now everythings fine. I guess they don't like it when you turn them off and on? The LED's in my vanity mirrors and map lights seem to be fine though.
out of the 5WLED, only 1 or two LED's flicker.
Old May 2, 2009 | 06:34 PM
speedracer g37's Avatar
speedracer g37
some, like me, don't like the look of leds for interior light. i looks very artificial and harsh. it looks nice on the exterior, but for me, putting leds on the interior would be like replacing all the lights in my house to tube flourescent bulbs.
Old May 2, 2009 | 07:39 PM
BiskitG37's Avatar
BiskitG37
My trunk light LED doesn't come on some of the time but it's a bad fit anyhow (can't put the plastic cover back over the bulb) - otherwise no problems with the rest of my LEDs.
Old May 2, 2009 | 07:47 PM
G2Envy's Avatar
G2Envy
Any ideas?
Crud...I'm having that problem with my license plate lights right now. Only one side of them are flickering though. Bought my lights from Superbrightleds as well.
I tried taking the bulb out and re-seating them but it's still flickering. I think I might try iJDM as well.
Old May 2, 2009 | 07:49 PM
shumby's Avatar
shumby
had the 5WLED on both my 09 and 08 with zero issues. However i did notice that one led in my 12 led map lights burned out. only noticed it cuz i took it out to show a friend what i did.
Old May 2, 2009 | 11:12 PM
Xcalibur's Avatar
Xcalibur
Vleds
Superbrightleds suck and will flicker out on you.
Every month I had to replace one... not Vleds.
Vleds for license plate and door lights :http://www.v-leds.com/Exterior-LED/C...85865-1-2.html
Looks better then the superbrightleds lights up brighter too.
Old May 3, 2009 | 03:46 PM
ONEighty's Avatar
ONEighty
All LED's will eventually die out, especially in confined places, they can't stand heat.
