Help Anybody having problems with LEDS?
Old May 3, 2009 | 05:02 PM
R3DL1N3R's Avatar
R3DL1N3R
get leds from autolumination.com
Old May 4, 2009 | 01:12 AM
w0ady's Avatar
w0ady
check your bulb connections. i have no problems in 4+ months with my superbrightleds.
Old May 4, 2009 | 01:19 AM
The LEDs you are using are all pretty much the same. LEDs will burn out no matter where you get them from if you expose them to extreme heat like in the headlight housing. Those of you with flickering problems are most likely having connection issues and not a problem with the LED itself. Check the prongs on the base of the LED and make sure they are not bent or out of place. Then check the connection in the bulb receptacle in your car. You might need to bend them slightly closer so they make good constant contact with the LED. This alone will likely solve most of your problems. If you feel certain that it is a bad bulb, put another working one in it's place and see if it flickers too. If not, it's the bulb. If it does, it's the connection.
Old May 4, 2009 | 02:15 AM
w0ady's Avatar
w0ady
ive got their leds in my city lights next to my fogs with no issue so far. however, i only use my fogs maybe once every couple of weeks since we do get fog here in jax.
Old May 4, 2009 | 06:48 AM
myk1013's Avatar
myk1013
Mine are from SuperbrightLED's, 6+ months, no problem so far.
Gefartenblatz
Nov 10, 2015 11:45 AM
xnick101
Sep 16, 2015 08:37 PM
CasperG37
Sep 14, 2015 07:46 PM
misc
Sep 14, 2015 05:16 PM
pauliewalnutzz
Sep 8, 2015 11:41 AM
