driver window doesnt inch down when door opens
Old Apr 28, 2009 | 11:08 AM
johnny872005's Avatar
johnny872005
So,
I finally got my g37, and I noticed my driver side window doesnt move down a tiny bit when I open the door (and come back up when I close it). Instead, it stays the same height.
Anyone know what could be causing this, and/or how to fix it?
thanks
Old Apr 28, 2009 | 11:13 AM
bucknasty's Avatar
bucknasty
Start your car. Push and hold the window buttons down...let them roll all the way down and keep them pressed down for 15 seconds. Now push the button to allow them to come up all the way and continue to hold the buttons up for another 15 seconds. That should do it, next time you might wanna search the forum before making a new post because some members are on here love to flame people for not searching....
Old Apr 28, 2009 | 11:18 AM
WhosUrBuddiee's Avatar
WhosUrBuddiee
^^^ Just reset the windows. If it doesnt work, call the dealership.
Old Apr 28, 2009 | 11:41 AM
MaxdOut's Avatar
MaxdOut
Originally Posted by johnny872005
So,
thanks
Out of curiosity, does the window actually hit anything?
Old Apr 28, 2009 | 12:12 PM
chasemyaccord's Avatar
chasemyaccord
I would think it may brush against the insulation strips, but not to the point where you couldn't shut the door. Can someone confirm?
Old Apr 28, 2009 | 12:36 PM
KnoxvilleG37's Avatar
KnoxvilleG37
^^^ what he said. Exactly what you need to do. Otherwise if that doesn't work, take it to Infiniti.... *and this is exactly what it says to do in the manual if the reset doesn't work*
Old Apr 28, 2009 | 01:29 PM
johnny872005
ya I tried the reset thing again (had tried it slightly differentw ay before) and have the same issue as before...
I know it reset cause window wouldnt auto up untill i held i up for 15 seconds or so. But still, when I open the door, window stays at same position
Old Apr 28, 2009 | 02:47 PM
KAHBOOM's Avatar
KAHBOOM
Super Moderator of Pwnage
That happened on my G35 coupe. There was actually something wrong with the actuator.
Old Apr 28, 2009 | 04:01 PM
KnoxvilleG37
Time for a trip to the dealership....sounds like some warranty work is in order.
Old Apr 28, 2009 | 04:44 PM
Keng's Avatar
Keng
There's trigger on the door frame on the car that cause the window to drop
Old Apr 28, 2009 | 07:47 PM
SEATOWNBOY's Avatar
SEATOWNBOY
Manual states to lower driver window, then raise window until it closes, continuing to hold button up for "3 seconds". Repeat for passenger side. I don't know where you guys are getting the 15 seconds instruction
Old Apr 28, 2009 | 08:52 PM
Mayu's Avatar
Mayu
Does not touch anything. I know since I had to unhook the battery for winter storage. In the spring you cant open the car without the key insert in the fob. With the battery disconnected and zero power, the door opened without the window drop. Did not touch anything.
Apparently this feature is to "seat the window properly for a better seal." If you think about it, sliding the glass plane up the rubber strip would generate a better seal than slaming the glass against it. So I dont consider this a gimmick... yet.
Old Apr 28, 2009 | 09:08 PM
aseo89's Avatar
aseo89
So,
thanks
i had the same problem, it shows you how to fix it in chapter 2 of the owners manual....really easy!
Old Apr 28, 2009 | 10:21 PM
johnny872005
yes I think that is the problem. I noticed the interior lights dont respond to the driver door (the one giving me the problems), and only respond to the passenger one.
andrewk523
Nov 11, 2015 05:49 PM
gipl
Oct 20, 2015 11:57 PM
xnick101
Intake and Exhaust
18
Sep 16, 2015 12:02 AM
