disconnecting the third brake light?
Old Apr 25, 2009 | 03:56 AM
DPE_G35's Avatar
DPE_G35
hey,
how do u disconnect the third brake light? (the one inside the car, next to the rear windsheild) ?
thanks!
Old Apr 25, 2009 | 04:53 AM
BradManUWF's Avatar
BradManUWF
Originally Posted by DPE_G35
hey,
thanks!
Um, find the connector on the end of the wire in the trunk and unplug it, lol.
Old Apr 25, 2009 | 08:02 AM
SEATOWNBOY's Avatar
SEATOWNBOY
In the trunk beneath the brake light, remove the pop rivets holding interior paneling (just enough to get to under the brake light, about 3-4 pop rivets). Once you have access to the area under the brake light, you will see a round opening in the chassis of the car stuffed with sponge-like insulation. There's a wire going through that opening, which is the brake light wire. Slowly pull it out and you will see the connector. Simply disconnect it and hide the ends so they don't rattle. No message will go off on your console if you disconnect it.
Old Apr 25, 2009 | 09:11 AM
EZDozzit's Avatar
EZDozzit
No Soliciting
Why are you disconnecting it? Did you add a spoiler to your G and don't want the redundant high mount brake lights?
tomro99
Nov 17, 2015 02:08 AM
inspector94
Sep 8, 2015 12:57 PM
ZachThomas
Sep 3, 2015 01:40 PM
Twista
Aug 30, 2015 12:23 PM
Skeletor06
Aug 2, 2015 12:54 AM
