Vehicle Alarm Impact Sensor
Old Jan 15, 2010 | 07:38 PM
  #31
Namir's Avatar
Namir
Originally Posted by Blackjack
I thought about doing that but didn't like the idea of having to carry around 2 remotes.
Exactly why I posted the question. I want to use the factory alarm so I can only have one key. I like having the fob as basic as possible with just my apartment key on it.
I have an 09 so I guess this would be plug and play with my car, I might have to pick this up.
Old Jan 15, 2010 | 09:26 PM
  #32
gtracing's Avatar
gtracing
Yes. Very possible. From what I understand it is pretty much plug and play, but note only the 09s and above are setup for this.
i have an 08 and i have it in my car...
Old Jan 19, 2010 | 02:44 PM
  #33
redwillow's Avatar
redwillow
20 Year Member
I just got mine today from grubbs. It is not exactly just plug and play it has 3 wires that tap into BCM wires and a ground that has to be connected... but it does seem pretty simple to do just looking at the instructions. I will post up more about it after i get it put in. It includes the sensor, instructions, wire ties, and even the wire tap connectors.
Old Jan 19, 2010 | 03:39 PM
  #34
whiddles's Avatar
whiddles
if i went with the viper i would leave the other remote in the keyfob holder at all times and only carry the viper
Old Jan 19, 2010 | 04:06 PM
  #35
Namir's Avatar
Namir
Thanks for taking the lead on this one. I was considering picking it up and being the experimenter to make a DIY for everyone. Let us know how it goes and post pictures of the install process.
Old Jan 20, 2010 | 09:37 AM
  #36
Blackjack's Avatar
Blackjack
I assume your car is Canada spec... US spec cars did not have it as an option in 2008.
Old Jan 21, 2010 | 01:27 AM
  #37
gtracing's Avatar
gtracing
really? doesn't us spec always get all the goodies first tho?? yea, it's canada 08 spec
Old Mar 27, 2010 | 04:03 PM
  #38
redwillow's Avatar
redwillow
20 Year Member
UPDATE: I tried to install this today and 1 of the BCM wires to tap on the instructions is not on my car. Instructions say application is for g37 2008~ so this should work.
Anyone that has this installed I need to know what wire the BLUE sensor wire is connected to on the BCM. Instructions say PINK wire - cavity 122 on M123 BCM connector...but that cavity has no wire on my car.
Old Mar 27, 2010 | 04:21 PM
  #39
Kidcane's Avatar
Kidcane
Florida G Club
^^Do you have an 08 or 09? I heard the instructions say 08-09 but it actually only works with the 09. Thats also what my service advisor told me.
Old Mar 27, 2010 | 04:28 PM
  #40
redwillow's Avatar
redwillow
20 Year Member
2009 sport with navigation.....and this should def work on the 2008 i'm looking at the serv manual wiring right now and it matches the instructions.
Can anyone send me or post up the 2009 BCM connector reference that shows the pins and wire colors? i only have a 2008 manual & they are different.
Old Apr 5, 2010 | 12:10 PM
  #41
redwillow's Avatar
redwillow
20 Year Member
bump....anyone got a 2009 service manual?
Old Apr 13, 2010 | 06:44 PM
  #42
Modme's Avatar
Modme
I have 2010 one. It does not show 122 or 123 wire under bcm. Skips from 121 to 124
Old Jun 15, 2010 | 12:35 PM
  #43
godzilla619's Avatar
godzilla619
anyone get this to work yet?
Old Jun 19, 2010 | 09:02 PM
  #44
gundam83's Avatar
gundam83
I have a 2010 and successully installed the impact sensor. Since we can't link to other fourms, type in "2010 g37 impact sensor" into google. One of the first results will be a knowledgebase where u can register and download the correct instructions for the sensor
vamarris
Dec 9, 2018 11:10 AM
conkus805
ECU Tuning / Dyno Data
46
Nov 19, 2015 07:49 PM
2K1 6T8
Oct 6, 2015 07:40 PM
Slapshot1
Sep 27, 2015 08:40 AM
SuicidalG37SGuy
Sep 10, 2015 06:01 AM
