HID Alignment
Old Dec 12, 2008 | 05:09 PM
CHEFONE's Avatar
CHEFONE
HID Alignment
Does any one know how to realign the hids? I threw in my new 6000k HIDS and now they are no longer lined up!!!Any tips!!!
Old Dec 12, 2008 | 06:24 PM
IvoryG's Avatar
IvoryG
If you have AFS lighting then you need a consult to adjust. If you non AFS you have to stick a long screw driver down the back side of the headlight to adjust. I haven't done mine yet. I am planning on doing it this weekend when I find flat area with a wall. After I dropped my car I need to bring them up a bit.
Old Dec 12, 2008 | 07:10 PM
Blackjack's Avatar
Blackjack
Hmmm... I have AFS and didn't need consult to realign. I was able to align vertically via the screws and the AFS corrected itself horizontally.
Old Dec 13, 2008 | 10:39 PM
IvoryG's Avatar
IvoryG
I was just going by what the factory manual says.
Old Dec 22, 2008 | 11:22 AM
PSYH's Avatar
PSYH
Post Whore
So is it a common occurrence for the HIDs to be misaligned whenever you install a new capsule?
Old Feb 18, 2009 | 09:22 PM
CHEFONE's Avatar
CHEFONE
What screws do we have to get to to adjust the HID alignment? I tried putting them back in another way but it didn't work. The lighting is all over the place and not lined up.
Old Feb 18, 2009 | 11:53 PM
AndrewDDS's Avatar
AndrewDDS
Are they lined up incorrectly in the horizontal or vertical plane? If it's the horizontal plane, they should correct themselves. If they don't self-correct, then take it to the dealership. If they're misaligned in the vertical plane, then follow this DIY thread.
https://www.myg37.com/forums/faq-and...djustment.html
Old Feb 19, 2009 | 12:36 AM
Weiboy718's Avatar
Weiboy718
i personally think they shouldn't need any alignment cuz the bulb is only one way in. you should check to see if the bulb is sitting flushed or not?
Old Feb 25, 2009 | 12:27 PM
CHEFONE's Avatar
CHEFONE
orite i checked out the bulbs and figured out the problem. when i put them in i didnt set them up right and they are not sitting correct but i cant remember how they were set up before i swapped them out. any advise? thanks!
Gefartenblatz
Nov 10, 2015 11:45 AM
rk325
Oct 13, 2015 01:51 PM
halfbreedcuban
Sep 27, 2015 08:58 AM
jfisher
Sep 9, 2015 04:17 PM
dlc1988
Sep 2, 2015 09:40 AM
