DIY: Headlight and Foglight Adjustment
Old Jan 14, 2009 | 11:34 AM
Xcalibur's Avatar
Xcalibur
Pre-determined Adjustment Measurement Chart - for Headlights
** Note these are pre-determined heights based on measuring from center of projector to floor and subtracting 2 inches to get the height adjustment measurement.
Stock no drop (rims & Tires) = 25 inches from ground
Eibach Pro (stock rims & tires) = 24 inches from ground
Eibach Sportline = ***
Tein H (non 08)Tech = ***
Tein S (non 08)Tech = ***
H&R Sport = (stock rims & tires) 23 inches from ground
DOT SAFETY NOTE*
Make sure after adjusting to test your headlights so that you are not blinding on-coming drivers.
With projectors you have a sharp cut-off line that is very noticeable to gage.
HEADLIGHT
What You will need:
1) Phillips medium sized screwdriver
2) Masking tape or Painters Tape
3) Pencil
4) Tape Measure
5) A place to do this at (example: parking garage - usually has leveled floors)
6) A Leveler - if you want it precise
7) Flashlight if its dark
Set-UP: - See third attachment below for these steps.
1) If you have your pre-determined adjustment height from above you may skip this first step. First measure vertically the distance from the ground up to the center of your headlight projector. Once you have your measurement (example: 2 feet & 4 inches) subtract 2 inches form your measurement to get your final adjustment measurement.
2) Now go to the wall and from the bottom up measure out your adjustment measurement twice at a distance of about 6 feet apart and create a horizontal line with the masking/painters tape - make sure to use the bottom of the tapes line as the exact distance to mark your adjustment measurement.
3) Now on the floor measure out 25 feet from the bottom of the wall out - do this twice gain at a distance of about 6 feet.
4) Now connect both measurements at the 25 foot mark to create a horizontal line on the floor as a marker to where you need to pull up your car - use the tape to mark this out. (This should be a 25 foot line from the wall)
5) Now pull your car up to the line so that your headlights projector lens lines up with it. Now your ready to adjust your headlights.
6) Now adjust the right beam to be above the left beam by 1/2 of an inch(this last step is dot spec). Done!
ADJUSTMENT INSTRUCTIONS:
1) Open your hood and if you look closely there are 2 rubber seals on both the left side and right side. These seals have 2 plastic rivets that hold them in place near where they meet the center rubber seal. You want to pop-up these plastic rivets with a screwdriver (or by hand - but grab as close to it as possible and pull up). ** You do not need to remove the entire left or right side seal - you will only pull it back to gain access to the headlight adjustment. ** SEE PICTURE "A" BELOW
2) Now if you look below seals (use a flash light) you will see the 2 adjustment gears for both Fog and Headlight (easy access and easy to see)
** SEE PICTURE "B" BELOW
3) Place the screwdriver in the slot and slowly turn to adjust by looking at the wall to see results.
4) Align cut-of line of the projectors light at exactly the mark on the wall (example: 24" inches - 2 feet)
5) Done!
FOGLIGHT
Use the same wall and distance (25 feet) after doing your headlights to adjust your fogs.
For your fog lights you want your lighting to just cut in half way below your headlights. This you have to adjust by eye since the lighting bleeds.
<br><br>
Attached Thumbnails Headlight and Foglight Adjustment-seal-end-removal-a.jpg   Headlight and Foglight Adjustment-seal-end-removal-b.jpg   Headlight and Foglight Adjustment-measurement-setup-guide.jpg
Old Jan 14, 2009 | 03:56 PM
ucla bruin's Avatar
ucla bruin
Very nice!
__________________
Old Jan 15, 2009 | 10:43 AM
Xcalibur's Avatar
Xcalibur
Originally Posted by ucla bruin
Very nice!
Thanks Man!
Have it done by Saturday. I'm going to edit it down to be much clearer and provide some visual measurement mocks too.
Old Mar 24, 2009 | 02:33 PM
elite's Avatar
elite
Tired of my lights aiming at the ground. Thank you for this!
Old Mar 24, 2009 | 02:37 PM
finagle69's Avatar
finagle69
just a note, DOT has the passenger headlight higher than the driver side by a few inches. you should include this in your DIY.
Old Mar 24, 2009 | 03:00 PM
ucla bruin's Avatar
ucla bruin
^Why is that?
__________________
Old Mar 24, 2009 | 03:40 PM
finagle69's Avatar
finagle69
^Why is that?
because you don't want to introduce glare to oncoming traffic.
Follow this DIY from G35 Driver. http://g35driver.com/forums/body-int...rojectors.html
It shows you proper DOT headlight aiming...
Old Mar 24, 2009 | 04:04 PM
ucla bruin's Avatar
ucla bruin
Cool. thanks.
__________________
Old Mar 24, 2009 | 05:35 PM
elite's Avatar
elite
I'm glad that "Search" button actually worked. The dealer was like "you can't adjust the lights they're sealed." I'm like STFU!
I typed in "Time Vampire" and this thread came up. Good stuff!
Old Mar 24, 2009 | 10:32 PM
myk1013's Avatar
myk1013
awesome DIY. thanks.
Old Mar 25, 2009 | 08:18 AM
Xcalibur's Avatar
Xcalibur
Thanks finagle69. I'll add a note later today in reference to ofset but I'm sure it's not inches. 1 inch is alot of adjustment. You should test your lights adjustment out by driving around after. Mine is a tad higher on the right side. My view over stock adjustment is almost twice the distance with no glare to other drivers. Projectors are easy to adjust because of the sharp cut-off line and are less likely to blind someone.
Old Mar 25, 2009 | 08:28 AM
Xcalibur's Avatar
Xcalibur
LOL! Thanks!
Thanks!
Old Mar 25, 2009 | 09:39 AM
w0ady's Avatar
w0ady
super easy to do. you just need flat spot, tape measure and philips screwdriver. i highly recommend it for anyone whos lowered their car.
Old May 16, 2009 | 08:21 AM
DrJones's Avatar
DrJones
need to do this adjustment this weekend. thanks for posting!
Old May 30, 2009 | 07:50 PM
san~man's Avatar
san~man
Here's an easy picture for reference:
