Driver's door handle key cover
Old Aug 18, 2008 | 09:43 PM
ecn113's Avatar
ecn113
Has anyone seen an identical driver's side door key cover used on the passenger side? Factory matched paint?
Old Aug 18, 2008 | 09:46 PM
amoney805's Avatar
amoney805
http://www.g35parts.com/9083/osc/pro...roducts_id=755
Old Aug 18, 2008 | 10:58 PM
speedracer g37's Avatar
speedracer g37
don't quite understand your question, but they all come factory painted and the door handle for our cars are used on many nissan models. e.g. nissan quest minivans.
edit: they are universal for front door, rear door, passenger or drivers side.
Old Aug 18, 2008 | 11:09 PM
ecn113's Avatar
ecn113
Thanks that's the exact part I was looking for.
Old Aug 19, 2008 | 12:09 PM
xeddyboi420x's Avatar
xeddyboi420x
any of you know if this is easy to install? i've heard that it doesn't "click" hence, not a perfect fit... want to share your experiences?
Old Aug 19, 2008 | 12:22 PM
speedracer g37
not correct. it slides forward and clicks in to where it meets the handle.
Old Aug 19, 2008 | 12:58 PM
Dipstix6996's Avatar
Dipstix6996
Mine didn't "click" when i went to put it on. On the inside of the cover you can see some rubbing on these little plastic tabs that stick out like 2mm. I just used my dremel and sanded it down little by little till it fit just right with the "click"
Old Aug 19, 2008 | 01:07 PM
xeddyboi420x
u guyz bought from http://www.g35parts.com/9083/osc/pro...oducts_id=755?
Old Aug 19, 2008 | 01:11 PM
Kidcane's Avatar
Kidcane
Florida G Club
I bought mine from Riverside Infiniti. I think thats where most peeps order from.
Old Aug 19, 2008 | 01:27 PM
speedracer g37
there are two ways to put it on. you can remove the lock mechanism through the plug in the door above the catch mechanism, or use a pick tool to remove the original by pulling the door handle open. i did the latter.
pull the handle open and shove a towel between the door and the handle. you can see where the escutchen clicks onto the base. i took a 90 degree pick tool to lift the clip and remove the cover. the new cover must be slid forward from the rear and pushed in to clip it to the base. you shouldnt have to dremel anything.
Old Aug 20, 2008 | 01:33 AM
Dipstix6996
I know how to put it on. I'm just sharing an experience that i had. Thanks for trying
Amaadkhan2k
Oct 4, 2024 01:20 PM
andrewk523
Nov 11, 2015 05:49 PM
lobuzz311
Sep 15, 2015 10:09 AM
OldG37
Sep 6, 2015 10:38 PM
