Glove box light not working!
Old Jun 22, 2008 | 02:41 PM
Scoobyj's Avatar
Scoobyj
Anyone know how to get to this light? I would rather get to it myself and change it (maybe to a LED), than have some guy at the delarship #$@& up my interior and paint job! I am changing the other bulbs to LEDs.
Old Jun 29, 2008 | 02:37 AM
g37vanbc's Avatar
g37vanbc
i believe it is only on when it is dark out if i remember correctly.
Old Jun 29, 2008 | 09:09 PM
Dieseldoug22's Avatar
Dieseldoug22
To access that bulb you need to pull the glove box out. The area where it hinges pulls up and unsnaps. Remove the glove box.
- Pull off the side dressing that is between the door and the dash.
- Then there is a panel under the dash that you pull down from the front and after 3 clips are off pull towards you.
- Then there are 7-8 screws that hold glove box carcass in. Remove those screws. Pull out the carcass and the light is on top of the carcass.
I am doing this from memory but that is pretty much it.
Old Jun 30, 2008 | 06:52 PM
Scoobyj's Avatar
Scoobyj
Thanks Dieseldoug,
I have the shop manual, so I will attempt this over the weekend. Did you go to a LED bulb? Do you know what type will replace the original?
Old Jul 3, 2008 | 12:15 AM
Dieseldoug22
That one I didn't change. I never look in there so I didn't find it necessary. If you can find it someone had posted what bulbs go where in the car.
superjoey
31
Mar 22, 2023 11:56 PM
warpeacelove
Oct 28, 2015 02:59 AM
Bn775
General Tech Questions
Aug 23, 2015 10:56 AM
bikerjosh
Aug 19, 2015 11:26 PM
Skeletor06
Aug 2, 2015 12:54 AM
