Head light problem
Old Feb 16, 2008 | 09:29 PM
SlateBlue G's Avatar
SlateBlue G
Head light problem
Hey guys Ive been running jmd 8000k bulbs for bout a month or so. Anyways at times when i would turn the **** from city lights to auto or on my right headlight does not come on.Leaving it from off to auto makes it go back to normal but if i quickly go on to off to on sometimes right hid bulb does not come on. Do you guys think i can be that i didn't properly tighten the area?IDK
Old Feb 16, 2008 | 09:47 PM
dnieto82's Avatar
dnieto82
the same thing happen to me when i had 8000k bulbs then my battery went dead so i jump started with my wifes car. so i notice d my light didn't come on. so i installed the OEM bulbs back on and still nothing... i took it to the dealership to have it looked at and they said they had to order a new control unit for the hid, but that did'nt fix it. So later they said it was a problem with the fusable link adn fixed it. my advice install your OEM bulbs back on and clean up the car as if you never did anything to it and take it to the dealership and have look at it. Maybe is a problem with something electronic cause mine was the right side too.
Old Feb 16, 2008 | 09:57 PM
MaxToTheG37's Avatar
MaxToTheG37
Super Moderator w/ Boost
So switching out to a different kelvin bulb is causing some problems?????
Old Feb 17, 2008 | 12:44 AM
dnieto82's Avatar
dnieto82
I"m not sure what is going on i switched my to 6000K instead and no problems so far.
Old Feb 18, 2008 | 10:51 AM
IvoryGT's Avatar
IvoryGT
non-oem quality bulbs do not last and much more tempermental. Try buying bulbs by a more reputable company. The difference in price will be evident in quality difference in the long run.
Old Feb 19, 2008 | 09:47 PM
UNV-IT46's Avatar
UNV-IT46
piaa hids are the way to go
Old Feb 19, 2008 | 09:51 PM
solopresident's Avatar
solopresident
if you have aftermarket hid's you can't turn them on and off very fast. they get to hot and will burn themselves out. so auto is not good. i had McCulloghs in my integ and they blew all the tiem b/c i would turn them on then off then on. or would flash high beams. its krappy
Chris Olson
Dec 29, 2025 07:59 PM
SS2006
Aug 27, 2024 07:33 PM
maybeg37
Sep 8, 2015 02:33 PM
Ricio1991
Aug 23, 2015 10:44 AM
Skeletor06
Aug 2, 2015 12:54 AM
