Who has changed their Parking/City Lights?
Old Dec 9, 2007 | 02:22 PM
finagle69's Avatar
finagle69
Originally Posted by Mike6mt
I had leds from superbrightleds.com in my Scion tC. Burned out in about a month. He said it's not meant for the headlight housing.
i've run them for a good while now both with and without fogs on at times.
i haven't had a problem with them at all. the city area seems pretty well disconnected from the main HID, which must help reduce the amount of heat the LEDs see.
Old Dec 9, 2007 | 02:26 PM
Mike6mt's Avatar
Mike6mt
Originally Posted by JLai
PIAA Super LEDs
I have PIAA Xtreme White fogs too, but I haven't taken pictures of them yet.
What bulb size are those?
Old Dec 9, 2007 | 02:35 PM
speedracer g37's Avatar
speedracer g37
So your city lights are LEDs correct? Do our city lights come on with the fogs or no?
the citylights come on with the regular headlights and stay on when the fogs are turned on
fogs: h1 citylights: 194
Old Dec 9, 2007 | 06:27 PM
Motor25's Avatar
Motor25
Originally Posted by ]\[ /-\ ]\/[
LEDs look so much better
LED bulbs actually make your HID headlight look like it has a yellowish tint
I like my lights to match
Old Dec 9, 2007 | 06:30 PM
Motor25's Avatar
Motor25
I changed out my parking lights (city lights) today to some Polarg white bulbs (non-LED)
Here are some before and after pics:
Parking lights BEFORE
Parking lights AFTER
New bulb matches the HID headlamps really NICE
Old Dec 9, 2007 | 06:32 PM
User 111021's Avatar
User 111021
Hey Speedracer where did you get the VLED's? are those the really expensive LED's that PIAA Makes!?
Also How did you guys all replace your leds and/or FOGS!? How long did it take, can someone please post up a tutorial PLEASEEEE!?
Old Dec 9, 2007 | 06:39 PM
JLai's Avatar
JLai
This might help...
Attached Thumbnails Who has changed their Parking/City Lights?-exterior_bulb_specs.jpg
Old Dec 9, 2007 | 06:43 PM
JLai's Avatar
JLai
VLEDs are not PIAA's.
Changing the fogs/city lights is simple. Take out both intakes and you'll have access to them...Although a real PITA cause there's not much room to work with. Just turn and unplug the old bulb and replace with the new ones. The H1 fogs have a hooking mechanism that is unlatched. After you put in the new bulbs, just put everything back. You won't need to go thru the wheel well unless you're doing the HIDs/turn signal/side marker lights.
Old Dec 9, 2007 | 07:00 PM
]\[ /-\ ]\/['s Avatar
HID headlights are already yellowish....i believe they're 4300k...just look white compared to everything else in the headlights
which is why i went with 6000k bulbs
Old Dec 9, 2007 | 07:02 PM
speedracer g37
vleds have their own site store on ebay. the big difference between them and the other led makers is that they offer an inverted v shaped bulb that spreads the light into the foglight housing. the last set i had in my g35 lasted over 18 months (sold the car, so i don't know if they are still working). they are extremely cheap to purchase at $1.99 a set and imo, perform just as well as any of the more expensive sets. i am sure that there have been heat induced failures in these leds among those on the board that have used them, but at $1.99, it's not that big of a deal.
i also changed the fogs from stock to sylvania silverstars...those on the otherhand were damn expensive $29.99 a set. they are much closer to white (4k) than the yellow stocks and put out better light.
http://stores.ebay.com/V-LEDS
Old Dec 9, 2007 | 07:03 PM
speedracer g37
are you saying that you changed the projector hid bulb?
edit: if you are, i completely disagree with you. the stock headlight projector color is near perfect white in my opinion. anything much above 5k starts looking blueish and you actually lose light illumination on the road.
Old Dec 9, 2007 | 07:13 PM
5000k is white...4300k is still yellowish which is wat our stock bulbs are
Old Dec 9, 2007 | 07:16 PM
speedracer g37
was there a big difference in the light output? how much did they cost?
Old Dec 9, 2007 | 07:46 PM
  #29
$60...i went with 6000k bulbs tho...but they'll be the same price
Old Dec 9, 2007 | 08:57 PM
  #30
DrJones's Avatar
DrJones
jumping on the change wagon very soon...
