A Few Lighting Mods (Lotsa Pics)
Old Dec 9, 2007 | 01:46 PM
  #106
]\[ /-\ ]\/['s Avatar
Originally Posted by leeladisky
okay: autolumination has 9006 LED bulbs that look fairly bright! I was thinking that I would replace the fogs (which I never use) with them for aesthetics. Any thoughts on this????
our car doesn't use 9006 bulbs....H1 for the fogs
Old Dec 9, 2007 | 01:54 PM
  #107
dmkozak's Avatar
dmkozak
Aren't the fogs HB4/9006?
And, to the poster who wants to use LEDs for the foglights, do some searching. I have only seen two kinds of posts about using LEDs for foglights; either they seem to be okay (in the short run) or they created a lot of problems.
Old Dec 9, 2007 | 03:25 PM
  #108
Old Dec 9, 2007 | 04:09 PM
  #109
dmkozak's Avatar
dmkozak
Right. My bad. I looked at the Sedan chart.
Old Dec 10, 2007 | 04:35 PM
  #110
DPMan's Avatar
DPMan
Ended up doing the 5's all around and the WLED in the trunk. Everything looks good. The map lights could be a bit brighter, but it still looks good to the point where im not gonna order different leds.
Old Dec 10, 2007 | 06:00 PM
  #111
BigJohnson's Avatar
BigJohnson
I just joined recently and saw the pics. They look great, I'll be doing the same shortly, thanks for the info.
Old Dec 13, 2007 | 03:32 PM
  #112
chris9012's Avatar
chris9012
how do you remove the cover on the door lights and map lights to gain access to the bulbs i want to pry it out with a screwdriver but im scared thats the wrong way and may damage something
Old Dec 13, 2007 | 04:02 PM
  #113
DPMan's Avatar
DPMan
For the door I used a fairly normal size screwdriver with masking tape on the end to "soften" it. Then pried it right where the plastic light curves.
For the map lights I used the same screwdriver, a small one might be easier but with tape also and pried on the end where it presses down.
They both just pop off.
Old Dec 13, 2007 | 04:08 PM
  #114
DoubleParadoxx's Avatar
DoubleParadoxx
Thanks for the info DP.... Mine should arrive next week and I was about to ask this same question.
Old Dec 13, 2007 | 04:33 PM
  #115
chris9012's Avatar
chris9012
yea thanks my are arriving soon hopefully it looks good
Old Dec 13, 2007 | 06:57 PM
  #116
DPMan's Avatar
DPMan
Also, careful on the map lights, if you do your door lights first and these are on for a while they get pretty hot
Once you pop out the door lights, unless you have some small fingers pliers may be useful to gently pull out the bulb.
Old Dec 13, 2007 | 07:09 PM
  #117
Comatose's Avatar
Comatose
Regarding the door lights, they are held by clips on their right/left ends, so you want to pry it out there. They come out fairly easily, and can be unplugged from the harness.
I found that I had to also pop the lens/cover off the door lights to change the bulbs easier.. they're held by tiny visible clips. I tried using pliers initially but was afraid I'd crack the bulb~
Old Dec 13, 2007 | 09:47 PM
  #118
DPMan's Avatar
DPMan
I didnt crack any bulbs with the pliers, just be gentle I also had to pop off the lens cover to change it.
Old Dec 14, 2007 | 02:40 AM
  #119
Wicked_limitz's Avatar
Wicked_limitz
im so pissed, but i changed out my door lights a few days ago and my cover on the passenger side wont click to close....i mean, its holding up but wont click like the drive side to confirm that its 100% sealed...did i pop them off 2 hard?
Old Dec 14, 2007 | 10:55 AM
  #120
08G37S's Avatar
08G37S
Nice wording at the end.
Anyway, you sure they going on the right way and not backwards? If so, give it a light, but firm tap to seat it right.
