A Few Lighting Mods (Lotsa Pics)
Old Dec 14, 2007 | 11:43 AM
  #121
chris9012's Avatar
chris9012
still waiting for them 2 come in the mail now im hearing bad stories on install wit clips pliers not clicking correctly. someone should do a DIY thread
Old Dec 14, 2007 | 12:01 PM
  #122
DPMan's Avatar
DPMan
The plastic cover that comes off goes on a certain way, make sure its not backwards.
Old Dec 14, 2007 | 12:54 PM
  #123
Wicked_limitz's Avatar
Wicked_limitz
alright, i'll give it a try later, hopefully thats the case.
Old Dec 15, 2007 | 12:39 PM
  #124
leeladisky's Avatar
leeladisky
1) Can someone explain how the trunk light/lens comes out so that the bulb can be replaced????
2) Instructions on the globe box light/lens???
Lee
Old Dec 15, 2007 | 12:44 PM
  #125
DPMan's Avatar
DPMan
The trunk light doesn't really pop off. The plastic globe looking part is hinged on one side and a clip is on the other. You need to pull out on the clip to pull the cover down. The hinge part is solid so it swings open like door not ever fully coming off, then the light just pops out.
I didnt do the glove box so don't know but I heard thats a hard one to do.
Old Dec 15, 2007 | 02:57 PM
  #126
Wicked_limitz
fukc! went out to try to fix the cover on my passenger side door and found out the reason why its not holding so well is beacause the white bracket is broke where the clear cover snaps on! its holding up, just not clicking to secure it and im so pissed! lol anyone know if that part is replaceable?
for those who didnt change the door lights out yet, word of advice, be gentle and take your time.
Old Dec 16, 2007 | 02:03 PM
  #127
leeladisky's Avatar
leeladisky
The entire assembly is fairly inexpensive to replace, about $27 with discount from a dealer....
Lee
Old Dec 16, 2007 | 02:31 PM
  #128
Wicked_limitz
^thanks buddy! going to my dealer monday to order one.
btw, whats that piece called? anyone know?
Old Dec 16, 2007 | 02:38 PM
  #129
Motor25's Avatar
Motor25
Originally Posted by peterbanks
Here you go, these are the 31mm x 5mm Vanity Mini 3 Led SMT Festoons from Autolumination. Perfect Fit.
Stock:
LED:
Just finished installing these bulbs... works and looks great
Old Dec 17, 2007 | 12:08 PM
  #130
chris9012's Avatar
chris9012
okay so i got my bulbs today and i need help cause i pryed the cover out of the door handle and one of the silver things popped off i cant find it but i noticed ont he passenger side it had 2 silver clips and the driver had one and wont click in properly so anyways i got the cover off. but how do i get the bulb out to replace it with the new 1 i tried pliers and twisted or do ipull it out im afraid ill break the bulb or something.
Old Dec 17, 2007 | 12:25 PM
  #131
DPMan's Avatar
DPMan
Did you take the white plastic cover off the part that comes out of the door? After doing that the light just pulls out. I had to use pliers to gently pull it out. If you use pliers dont use needle nose ones as the plier opening is not wide enough.
Old Dec 17, 2007 | 12:26 PM
  #132
08G37S's Avatar
08G37S
I pulled my bulbs straight out.
Old Dec 17, 2007 | 03:09 PM
  #133
chris9012's Avatar
chris9012
i unplugged the wire got the lens off and the bulb is attached to the white part but im not sure how to get it off i will try just to pull it straight out
Old Dec 17, 2007 | 08:57 PM
  #134
DPMan's Avatar
DPMan
Yeah from there just pull it out, for me it kept slipping if I tried with my fingers, so i did pliers, no breakage.
Old Dec 17, 2007 | 09:20 PM
  #135
chris9012's Avatar
chris9012
yeah i got it its so easy i dont know whats wrong wit me once i did it the first time it was a joke. anyways it looks pretty good map lights could be a bit brighter but it looks good
