A Few Lighting Mods (Lotsa Pics)
Old Dec 29, 2007 | 01:29 AM
  #151
Wicked_limitz's Avatar
Wicked_limitz
Originally Posted by chris9012
http://youtube.com/watch?v=np26n2BYz6o
does anyone know how to do that. thats what i really want in white
yeah thats pretty sweet!
Old Jan 3, 2008 | 11:32 AM
  #152
RedG37SNC's Avatar
RedG37SNC
Hi all, first post to this forumn . Great idea on the lights, thanks for the info.
I've been thinking of getting the illuminated Kickplate but I'd want to change out the bulb for a Red LED since I have a Red G. I was just wondering if anyone has tried to replace this bulb yet and know the specs.
Old Jan 3, 2008 | 07:12 PM
  #153
RedG37SNC's Avatar
RedG37SNC
Has anyone noticed any issues replacing the lights, I read one post where he said the map lights never went off all the way and glowed. Just wondering if anyone else has had this problem?
Old Jan 3, 2008 | 07:58 PM
  #154
DoubleParadoxx's Avatar
DoubleParadoxx
Thats by design, there will always be voltage on that circuit. They're on, but you cant notice them unless you actually try to.
Old Feb 29, 2008 | 10:36 PM
  #155
J.Oh's Avatar
J.Oh
Originally Posted by RedHerring
I used a flat screwdriver with masking tape over the blade. Slide it between the white moving part and the mount, toward the front of the car, and just pop it off with gentle pressure pulling toward the floor of the car.
The doors lights just pop out, I was able to use just my hands. Grip it at the edge on the bottom closest to the outside of the door and pull toward the inside and it will pop out. It is clipped in and comes out and goes back easily.
uhh anyone help or tips i seriously cant get my bulbs out of the housing i think my fingers are to fat oh ill post pics up as soon as im done im using UV lights instead there pretty nice everything glows
Old Feb 29, 2008 | 10:52 PM
  #156
aznutx's Avatar
aznutx
if you're talkin bout the door lights, just use a flathead screwdrivre, put a piece of cloth over it, and gently pry off, they surprising are easily maybe start with the bottom first, then the top
Old Feb 29, 2008 | 11:19 PM
  #157
J.Oh's Avatar
J.Oh
i used pliers with lots of tape =D sticky side out so it would hold onto the bulb so i wouldnt put to much pressure on it also im in NJ and its snowing like a mother right now.. lol the things i do for my car in the snow just to change bulbs i actually have 5led bulbs i JUST ordered 12leds because its not as bright as i would like on the inside im basically doing what the first poster did except with UV lights including the back licence plate will post pics when my other set of bulbs get here
Old Mar 1, 2008 | 01:24 AM
  #158
TerribleONE453's Avatar
TerribleONE453
Yea i used a screwdriver with a towel over it..
Old Mar 1, 2008 | 09:48 PM
  #159
J.Oh's Avatar
J.Oh
i dont get the screw driver with a towel process to remove the bulb not the housing like the actually bulb wouldnt it break?
Old Mar 1, 2008 | 10:11 PM
  #160
NotUrG's Avatar
NotUrG
I grabbed mine out with a needle nose pliers and gentle grip. They came out with no problems. When I did it, it was too cold and I couldnt get a grip on the bulb, so that is why I used a pliers.
Old Mar 2, 2008 | 01:44 AM
  #161
aznutx's Avatar
aznutx
i just did it with the cloth screwdriver method slowly withalittle pressure it popped out, cus i think direct metal to glass more prone to breaking as the cloth provides a little damper
Old Mar 2, 2008 | 10:57 PM
  #162
shumby's Avatar
shumby
Couold not get the bulbs out either had to get my wife to do it. My fingers were to big. Did i ever feel like a *****.
Old Mar 18, 2008 | 10:14 PM
  #163
rawr's Avatar
rawr
awh that sucks..i was just trying to order them and they are out of the 12's for the interior Ohh well ill just wait until the get them back in stock.
Originally Posted by Comatose View Post
great stuff! My only beef is from reading other similar threads, that these LED's dont appear to last more than a few months?? (really dissappointing considering lifespan is usually a beneft of LED's...)
I think i might end up just sticking with traditional (superwhite) incandescent bulbs...
Only time will tell. I'll let you guys know how long they last.
And as for that...just save the old incandescent bulbs and reinstall them if the LEDs fail : )
Old Mar 18, 2008 | 10:38 PM
  #164
rawr's Avatar
rawr
would i be able to fit the 9's for the map and trunk since the 12's are out of stock?
Old Mar 18, 2008 | 10:41 PM
  #165
rawr's Avatar
rawr
Would i be able to fit the 9's instead of the 12's since they are out of stock?? any suggestions?
