Backup camera No Signal - Nifty City Radio
Old Mar 9, 2024 | 10:21 PM
ActuallyFlo's Avatar
ActuallyFlo
Hey Guys,
i bought the Tesla Screen from nifty city and installed it. All wires are connected but when im
im reverse it says No Signal from the Back up camera. The PDC is working.
Infiniti G37x Sedan 2011 maybe somebody knows the problem and can say me what to do.
Old Mar 10, 2024 | 11:43 AM
ILM-NC G37S's Avatar
ILM-NC G37S
We could offer 1,001 potential causes/ fixes but at the end of the day we are flying blind when it comes to these things as every single one is different. Why not just contact these "Nifty City" people and have them troubleshoot?
Old Mar 10, 2024 | 11:47 AM
ActuallyFlo
i already did this but they cant help me i dont know why i thought maybe someone in this community knows what it could be or had the same issue fixed
Old Mar 10, 2024 | 12:14 PM
13_SkylineSedan's Avatar
13_SkylineSedan
I suspect the number of forum members who have done exactly the same mod and run into the same problem must be too low to get a reply. No harm in asking though.
That rig should support your OEM camera so check the instructions and be sure you've connected things correctly. Also be sure you haven't lost any fuses during the install. We also don't know if your car had a base AV system, Bose or Bose w/NAV. Did the camera work correctly before you put in the new system?
The camera is supposed to get power when you put the car in reverse so that is something you could check at the camera. Also, the camera's wires travel into the trunk lid through the flexible conduit near the trunk's hinge. It might be worth checking those wires to be sure nothing is frayed or broken.
Just some ideas.
Old Mar 10, 2024 | 01:12 PM
ActuallyFlo
Just some ideas.
First of all really thank you.
i have the Bose System with OEM Navigation and Backup camera. I will check the things you told me when im back home.
but i dont think its a wrong connection i disassembled and assembled the radio 3/4 times to be sure Everything is Connected right but everytime there was no Signal. I also assembled the oem radio in between to check if maybe the camera is broken but then everything is working fine
Old Mar 10, 2024 | 04:43 PM
Thedhc's Avatar
Thedhc
Check the fuses
Check dipswitch (if any) settings on the nifty device
Check in options/configuration for nifty if oem or after market camera is selected. No signal means most likely its looking for something thats not connected, so could be aftermarket option.
Also see their pdf and search for camera:
https://www.niftycity.shop/pages/troubleshoot-your-module
JT05
Nov 16, 2019 11:35 AM
flyfisher111
Aug 11, 2019 05:31 PM
zzww1251
General Tech Questions
Feb 15, 2016 12:56 PM
coupecruisin
Feb 6, 2016 11:23 PM
landslide03
Sep 11, 2014 09:31 AM
