NAV Upgrade/Conversion Parts for 2010+ G37 Q40 and Q60
Old 08-24-2021, 04:35 PM
OWC
OWC's Avatar
This is quick guide on what parts are needed to upgrade a 2010-2015 G37, Q40, or Q60 to a 2010-2015 NAVIGATION System w/BOSE.
Only four NAV parts are required for the conversion:
(1) Touch Screen Display (2) Control Panel for Display (3) Faceplate / Climate Panel (4) NAV Unit / Radio Receiver
Cars with BOSE Audio Systems only require those parts.
Cars with Base Audio Systems require all those parts plus the addition of a suitable amplifier to power the car speakers.
Base Audio cars without a factory rear camera should also install a microphone for voice communication.
PARTS FOR THE CONVERSION
From a 2010-2015 G37, Q40, Q60, EX35, EX37, or QX50 with Nav.
Part No: 28091-1BY3A, 28091-1BY3B, 28091-1BY1E, 28091-1BY1F, or 28091-1BY3C.
From a 2008-2015 G37, Q40, Q60, or EX35 with Nav.
Part No: 28395-1UF1A, 28395-1UF2A, 28395-JK605, 28395-JK65B, or 28395-JK66B.
From a 2010-2015 G37, Q40, or Q60 with Nav. Part No: 25391-1UF3A.
or
From a 2008-2009 G37 with NAV. (These faceplates have a hard drive slot on them).
Part No: 25391-JK64B or 25391-JK65B
Part No: 25915-1JA0B, 25915-1JA1E, 25915-1JA2B, 25915-3LZ1A, or 25915-3LZ1C
(Note – these nav units don't natively support RCA inputs; USB input only).
or
From a 2010 FX35, FX50, or EX35 with Nav.
Part No: 25915-ZX74A or 25915-JJ52C
(Note – these nav units support both RCA + USB inputs, however they may require dealer reprogramming to activate the rear camera, since those vehicles have around-view monitoring).
(5) 4+ Channel Amplifier - BASE Audio System cars Only The 2010+ NAV Unit/Radio does not have a built-in amp like the Base audio radio unit, so an external amp needs to be installed to power the car speakers.
(6) Microphone, for voice - Base Audio system cars with no factory rear camera
These cars don't have microphone, and so should install one. From a 2008-2015 G37, Q40, or Q60. Part No: 28336-JK60A, 28336-1VZ0A, or 28336-1VZ0B.
---------------- END OF PARTS LIST ----------------
With the correct parts all you need is to either purchase a Harness Adapter Kit such as this one: https://www.ebay.com/itm/333982567715
Or Get a Factory Harness From a 2010-15 NAV Vehicle, and then pin-out, cut, & splice the connectors to your existing harness, using the FSM wiring diagrams as a reference. In some cases, additional wiring (like for the microphone) would also need to be fabricated.
And that's all there is to it.
Everything can then be installed like it came from the factory. Get the parts you need, adapt the wiring and away you go! Updated Nav, Bluetooth, Display, etc.
Hope that helps.
OWC
10-26-2023 02:11 PM
GFTW
05-01-2021 09:19 PM
GFTW
01-16-2016 04:19 PM
gammamotors
44
12-31-2015 12:48 AM
Quick Reply: NAV Upgrade/Conversion Parts for 2010+ G37 Q40 and Q60
