Dead gauge cluster
Old May 30, 2020 | 05:00 AM
aalmanzar272's Avatar
aalmanzar272
Dead gauge cluster
I was recently taking apart my dash to switch it out and when I went to put it back together it started to act funny. The gauges cluster is dead and also when i turn off the car it doesn't turn off but goes to ACC so i have to turn it on again and then hold down the button for it to completely shut off. Really don’t know what to do at this point
Old May 30, 2020 | 09:00 AM
telcoman's Avatar
telcoman
Assuming that you disconnected your battery prior to taking apart your dash?
Use your multi-meter to check for blown fuses.
Old May 30, 2020 | 10:08 AM
aalmanzar272
I had someone check the fuses and they are fine
Old May 30, 2020 | 10:09 AM
ILM-NC G37S's Avatar
ILM-NC G37S
More than likely you either blew some fuses, as Telcoman suggested, or you mismatched some wiring connectors. There are some connectors in the center stack (where the radio, screen, switches are) that can easily get mixed up.
Your gauge cluster, and start button, is tied directly to the Unified Meter AC Amp- a little white plastic box that is mounted to your radio/CD headunit. There are two connectors. It is VERY EASY to mix them up with some that go to the headunit.
Best advice, check fuses, check connectors. If all else fails, download a copy of the BCS (Body Control System) section of the factory manual and start verifying wires.
Old May 30, 2020 | 11:06 AM
aalmanzar272
Yea the two cables that are marked with yellow tape. Those are fine and then the other wires in the back of the stereo are connected and are fine. It isn’t the fuses either so those are ruled out. Any other suggestions other than verifying the wires? This is really stressing me out
Old May 30, 2020 | 11:19 AM
ILM-NC G37S
You checked ALL of the fuses? Remember there are three (3) fuse panels.
If everything above checks/ed out good, then aside from verifying the connectors and wiring, the prognosis looks grim. Retrace ALL of your steps, double check everything that you disconnected and removed.
I would personally double check the connections at the amplifier first as that is the main driver for the gauge cluster, start button, HVAC, etc.
Best advice: be patient and don't get stressed out. Take your time, take breaks as needed, and go step by step. Wiring can be nerve wracking, but it can be figured out.
Jan 11, 2023 01:21 PM
Wreckfan
General Tech Questions
Feb 24, 2020 08:57 AM
cribbj
Mar 12, 2019 09:31 AM
unknown2k1
Mar 4, 2013 01:44 PM
NIGHTLFEphantom
Nov 21, 2009 08:54 AM
