Sonar light keeps blinking
Old Jul 1, 2019 | 03:28 AM
Etiennear's Avatar
Etiennear
When i turn on the car, the sonar light keeps blinking nonstop, when i press the switch the light goes on and stays on without blinking, if i press it again, the light starts to blink again non stop.
Anyone has experienced this before?? What should i do?? Any way to do a diagnostic?? I put the scanner and it said no fault code.
G37 2010 coupe
Thanks in advance.
Old Jul 2, 2019 | 12:08 PM
Surfnazi's Avatar
Surfnazi
Did you hit something or are they something on them? Try unplugging battery for 30 mins
Old Jul 2, 2019 | 01:29 PM
Etiennear's Avatar
Etiennear
I did not hit anything but i bought with the sonar not working and doing like this
Is there any fuse for the front ones?? The rear are working but the front are not
Old Jul 2, 2019 | 06:58 PM
Surfnazi's Avatar
Surfnazi
I'm guessing previous owner hit something replaced bumper and didnt replace damaged sensors
Old Jul 2, 2019 | 09:25 PM
Etiennear's Avatar
Etiennear
I took it to the garage and put on scanning, there were no fault codes seen.
Im thinking to open the front bumper and check the sensor connection.
Just i need to know, if one sensor is defected, the others will stop working as well untill this is fixed or how the system runs?
Old Jul 2, 2019 | 09:50 PM
Bommerang's Avatar
Bommerang
Yeah if one sensor is bad the rest wont work. My car has a sensor thats completely ripped out and the light flashes 24/7 when you have the system on.
Old Jul 3, 2019 | 05:39 AM
Surfnazi's Avatar
Surfnazi
The sensors will keep issue until bad one is fixed. Unplug 1 at a time but if it was damaged it will be pretty obvious
Old Aug 16, 2019 | 08:41 PM
kicksdechris's Avatar
kicksdechris
just got rear ended today and the same is happening to me....i was only hit at about 5-7mph but it was strong enough to f'up the sensors.
Old Aug 19, 2019 | 11:57 AM
Surfnazi's Avatar
Surfnazi
The sonar sensors dont take much to damage them
CANT COMPLAIN
G37 Convertible
Jul 22, 2019 12:24 AM
cydonian66
13
Jul 30, 2015 10:48 AM
eauty
Feb 18, 2010 11:18 AM
ohseedee
Nov 16, 2007 09:54 PM
bboysteele
Nov 16, 2007 01:16 PM
