PLEASE HELP: IPOD adapter questions.
Old Apr 30, 2019 | 02:57 PM
ikbb's Avatar
ikbb
so i'm a new G owner. YAY! i have an 09 Vert w/ tech nav pkg.
i bought a bluetooth 30pin adapter:
https://www.ebay.com/itm/Naxa-NAB-40...72.m2749.l2649
i plugged it in, and there is a light, i was able to pair with my phone, no problem.
but when i select source to ipod, it says "no ipod connected" on my nav screen.
i read that we need a 12v to 5v converter to power the device:
https://www.ebay.com/itm/12V-TO-5V-C...frcectupt=true
but i'm thinking if i already have power at the unit, do i still need it? maybe to trick the system that something is plugged in?
but its weird that its going 12 to 5 vs the other way around.. meaning the car should sense that something is plugged in, since i do have power.
anyway, decided to post here and see if anyone has any ideas for me, or ran into this before.
thank you in advance.
Old Apr 30, 2019 | 09:32 PM
saywat?'s Avatar
saywat?
maybe try the bovee brand? theres a thread here about it some say it works some say it didnt. theres also a youtube from a g37 owner said it works
Old May 3, 2019 | 06:29 AM
jpowersjr2's Avatar
jpowersjr2
While it's not perfect, I like my Bovee.
Old May 3, 2019 | 03:05 PM
RA081224's Avatar
RA081224
I can't be 100% sure but believe the problem is the Naxa device only provides a "speaker dock" which is most likely only the audio output from the IOS device. It likely does not provide the handshaking that the Infinity head unit requires to verify/control an IOS device via the Apple Aux Protocol. This is why the car doesn't detect an iPod.
The 12V to 5V conversion is only required if you expect to power a newer IOS device (with lightening connector) via an older 30 pin connection. Your Naxa device powers up so the DC connection between the Naxa and the car is solid. The Naxa pairs with the phone so the Bluetooth connection is solid. The problem (I'm guessing) is the sense and control signals the Naxa is not providing to the head unit. Note the Bovee devices are described as Bluetooth adapters specifically for in-car media systems
Old May 6, 2019 | 08:41 PM
gromaudio's Avatar
gromaudio
MYG37.COM Sponsor
You do not need any additional power, the device supposed to get the power from the iPod 30-pin connector. It looks that the device is simply not sending the signal to the stereo. Try to restart the car and see if the stereo will "see" device connected. For solid factory looking solution you can look into our GROM BT3 Bluetooth car kit product.
mmnjtwa
May 28, 2015 12:20 AM
Moofer
Aug 4, 2013 02:04 PM
consultant1027
Nov 12, 2010 12:57 AM
1124sjk
Jan 9, 2010 03:42 AM
