Fuse box wiring help
Old Dec 21, 2018 | 11:24 PM
TIMSMAIL832002's Avatar
TIMSMAIL832002
I have a 2012 g37x and in was trying to get the obd2 port to work. I didnt notice the coorect fuse at first so i jump the port from one of the empty fuse holders that had power coming from it. Long story short it accidentally touch a piece of metal and now the car wont start
Old Dec 27, 2018 | 12:17 AM
dkmura's Avatar
dkmura
20 Year Member
Long story short- you need to take it to a dealer or trained tech for diagnosis...
Old Dec 27, 2018 | 01:25 PM
nealinnevada's Avatar
nealinnevada
There is "won't start" and "won't start". Does the starter turn the engine over, but won't start OR the engine won't turn over? This info will help in the diagnosis of the problem.
Old Dec 31, 2018 | 03:21 PM
crookncastle's Avatar
crookncastle
wow this is absolutely one of the dumbest bonehead moves i ever heard of. makes no sense why you would jump power from an empty slot on the fuse box to another and in doing so you arced it to ground. if i was you, first check the main fuses, perhaps that was blown. if you don't know what you are doing leave the damn thing alone. modern cars are loaded with electronics which are much more sensitive to voltage spikes and short to ground. oh wait sensitivity, i think i just also described a millenial too.
Old Jan 1, 2019 | 10:49 AM
Corprin's Avatar
Corprin
see: Dunning-Kruger Effect
Old Jan 3, 2019 | 01:48 PM
This is going nowhere. Moved and closed.
2009G37Bandit
12
Jul 4, 2012 08:38 PM
xzeus
Jun 28, 2012 09:58 AM
Krebo
Aug 16, 2010 02:01 AM
DJ Hellfire
Oct 6, 2009 12:20 PM
GeeeeOhhhh
Mar 20, 2009 04:26 AM
