Tesla Style Screen Thread
Old Mar 16, 2019 | 11:19 AM
  #166
ILM-NC G37S's Avatar
ILM-NC G37S
Originally Posted by ARogers502
Any suggestions? I have sent an email to Phoenix Radios just now but figured I'd try asking here too.
I do not know how the Phoenix unit is wired to the factory harness- yes, they say it is plug-and-play but I do not know what connectors get used. That said, most of your symptoms point to the Unified Meter/AC Amp. There is a white, plastic, rectangular box mounted to your headunit that has two IDENTICAL connectors plugged into it- this is the amp. If these connectors get mixed up, or plugged into the wrong slots, many of these symptoms will arise.
Again, without seeing firsthand what you have it is hard to remedy here. Just double check all of your connections and see what Phoenix recommends.
Old Mar 16, 2019 | 05:28 PM
  #167
ARogers502's Avatar
ARogers502
Originally Posted by Dat240zg
Honestly, and without being able to see your connections, I’d unplug it all and start from the beginning. When you did the install, did you plug the Phoenix harness in to the radio first? If not, I’d start there and use their picture to make
sure the radio is plugged in correctly.
Based on what you’re describing, it sounds like one of the factory harnesses may be hooked up wrong.
If you can’t figure it out, take some pics of the way you have it connected and post them up.
You were correct. There are two harness connectors that will fit the white plastic box plug. I swapped those and the car will now crank, no fan turns on and the backup lights don't turn on...That being said, the car will crank but not start. That's the last issue I have to iron out.
Old Mar 16, 2019 | 05:30 PM
  #168
ARogers502's Avatar
ARogers502
Correction: There are two factory harness plugs that fit the same way in the white plastic box. Swapped those and got the car to crank. Had to disconnect the battery once to get the car to start.
Old Mar 16, 2019 | 05:35 PM
  #169
ARogers502's Avatar
ARogers502
There is no where to plug this one as the Phoenix harness has a blue gps antenna plug instead.
There is nowhere on the Phoenix radio or the vehicle to plug this in.
There is nothing coming from the Phoenix harness that plugs into this factory plug.
This plug is identical to two other plugs from the car and will match up with the Phoenix USB harness. none of my symptoms change depending on which plug I hook the USB harness to.
This shows that I have all the harnesses plugged into the Phoenix radio as directed in the instructions.
Old Mar 16, 2019 | 05:38 PM
  #170
ARogers502's Avatar
ARogers502
This harness came with the radio. There is nowhere on the car or the radio harness to plug this in. According to the Phoenix YouTube channel tutorial, they only show plugging up the RCA's but no information on where the white plug connects. I have disconnected everything and tried plugging it into any of my factory harnesses or the Phoenix harnesses and there's nothing it fits.
Old Mar 16, 2019 | 06:01 PM
  #171
ARogers502's Avatar
ARogers502
I currently cannot reach anyone at the tollfree Phoenix Android Radio phone number. It's 3pm in California and they close at 4pm. Not sure I'm going to have this up and working this weekend.
Old Mar 16, 2019 | 06:11 PM
  #172
ARogers502's Avatar
ARogers502
I also just opened my buddies unit and discovered that they didn't send his wiring harness. They sent all the aux, mic, camera, usb harnesses etc...but they didn't send the main harness with all the connections to the factory harness. SMH.
EDIT: I just checked my mail randomly and had a package I wasn't expecting. My friends harness was in the mail. LMAO WOW what are the odds?
EDIT 2: I wonder if the harness I just received is mine and not his? We shall see.
Old Mar 16, 2019 | 06:14 PM
  #173
ILM-NC G37S
Just for reference:
Pink Connector: XM SAT antenna
BLK Square Connector: GPS
GRAY/BLUE: USB
GRAY/BROWN: GVIF Display
The 4-pin flat connector looks like the camera but I can not tell in that picture.
At this point best advice is to put your factory system back in and wait until you hear back from Phoenix.
Old Mar 16, 2019 | 06:40 PM
  #174
ARogers502's Avatar
ARogers502
Just for reference:
GRAY/BLUE: USB
Should I use the pink connector from my factory harness, or the blue connector with the GPS antenna that came with the radio?
Do I not use the BLK square one?
Gray/Blue USB is good to go
Gray/Brown (I have two) not used? I have one that's at a 45 degree angle with an inline fuse and one is straight with no inline fuse.
The 4 pin flat connector confuses me if it's for the camera because I have an RCA male/female connector with "factory camera" tags on them.
Old Mar 16, 2019 | 07:13 PM
  #175
ARogers502's Avatar
ARogers502
Update: I had one of the wrong factory harnesses plugged into the white plastic box that sits in the dash. I swapped those plugs and the car started.
Old Mar 16, 2019 | 07:20 PM
  #176
ARogers502's Avatar
ARogers502
Currently the backup camera does not work.
Blower fan does not turn on. The screen shows that the fan speed is turning up and down when I push the button but the fan doesn't actually blow.
Check engine light is on but no codes.
ABS and Brake light is on but no codes.
I'm about to try swapping harnesses since the other one arrived in the mail today.
Old Mar 16, 2019 | 07:53 PM
  #177
ILM-NC G37S
Glad most of the problems are sorted- that ACAmp (plastic box) can create a lot of problems.
The gray/brown you will not need (you have "two" because it is both ends of the same cable that connects your "old" headunit to your "old" display). I can't help with the others as I don't know how the Phoenix unit is designed (internal XM/GPS antennas, etc.)
At least you are on the home stretch....
Old Mar 16, 2019 | 08:46 PM
  #178
ARogers502's Avatar
ARogers502
Well swapping the harness is not a choice. The widest plug on the other Phoenix harness is not as wide is the widest factory plug in my car.
Old Mar 17, 2019 | 12:27 AM
  #179
ARogers502's Avatar
ARogers502
Blah. I just switched back to my factory radio and I still have no blower fan, still have a check engine light, abs light, traction light and brake light on. I think I need to go back over the fuses again.
EDIT: No blown fuses found. I checked with my fluke meter and was skeptical when I found nothing, so I pulled each, one by one and found none blown.
Old Mar 17, 2019 | 10:28 AM
  #180
ARogers502's Avatar
ARogers502
Additional information. I just noticed that the airbag light is blinking on my dash and my backup camera does not work on the factory radio anymore.
I just went to have my codes read and they have found a lot I will show them in just a few minutes. I'm also starting to notice a lot of other issues. I currently don't have the option to manually shift it doesn't even show up on the dash and I have no turn signals.
Transmission:
p1815 Manual mode switch circuit
ABS:
c1109 battery voltage out of range
U1000 CAN communication circuit
BCM:
U0415 Vehicle Speed Signal
B2193 Chain of BCM - ECM
B2553 Ignition relay
B2557 Vehicle speed
B2562 Low voltage
B2601 Shift position
B2604 PNP Switch
B2605 PNP Switch
B260A Igntion relay
B260F Engine State Signal Lost
B2617 Starter Relay Circuit
B261A Push Button Igntion Switch
C1729 Vehicle Speed Signal Error
Multi Audio Visual (AV)
U1217 Bluetooth Module
U1229 iPod Certification Error
TPMS:
U1000 CAN Communication Circuit
