Sub + Amp install problem..
Old Jul 7, 2018 | 03:02 PM
BobbyKasoca's Avatar
BobbyKasoca
So I recently started hooking up my amp and sub to my 2011, x coupe. And I finally got everything connected and working except im not getting sound. I tapped into 23-26 two different times then I tried tapping into the front speakers and still not getting a sound out of my sub. I viewed multiple threads and pictures of what to do, Even followed a diagram on the wiring. Does anyone have any idea of what I should try next?
Old Jul 7, 2018 | 03:23 PM
telcoman's Avatar
telcoman
Defective amp?
No power?
Missing ground or audio signal return?
Bench test it!
Telcoman
Old Jul 7, 2018 | 04:11 PM
BobbyKasoca
Originally Posted by telcoman
Defective amp?
No power?
Bench test it!
Telcoman
Amp should be working fine, I had it connected to my other car recently and it worked great. it’s also turning on and has good ground. Just no sound I’m not sure what to do as of now
Old Jul 7, 2018 | 05:52 PM
BobbyKasoca
Defective amp?
No power?
Bench test it!
Telcoman
I followed this diagram, first i tapped into the 23-26 two different times and wasn’t getting a sound from the sub, now I tried 33-36 and still not a sound.
Old Jul 11, 2018 | 07:50 AM
smitty37g's Avatar
smitty37g
Do you have the wire going to the aftermarket amp high inputs or low inputs??
If you are using the high inputs, you will need to tap into 31 and 18, or the corresponding for the front speakers, which is on a different plug. If you are using an the low inputs, then tapping those wires should be fine.
Dumb question, is the amp turned up??? sometimes we miss the dumbest things.. all the wires between the amp and the sub connected??
Old Jul 11, 2018 | 07:59 AM
BobbyKasoca
thank you for your response. I just figured it out last night. I have a little built in fan in my amp and when I’d turn the car on i saw the fan turn on and assumed it was getting enough power from the remote. The problem is I wasn’t getting enough remote power for the amp to fully turn on. All the wiring was correct just not even remote power being sent to the amp. I had to get the power from the fuse box in Now everything works great
Old Jul 12, 2018 | 08:23 AM
Landshark's Avatar
Landshark
i've read some amp models (Rockford Fosgate?) require more power for turn on than the bose harness will provide, and you have to go to the fusebox.
glad you got it sorted out ...
Old Jul 18, 2018 | 06:15 AM
Surfnazi's Avatar
Surfnazi
All aftermarket add in subs need a power supply run from the battery
Old Jul 18, 2018 | 07:18 AM
Landshark's Avatar
Landshark
i said "turn on", as in the remote turn on connection that signals the amp to power up on ACC/ignition.
yes, the main power needs run from the battery.
ImportPartsPro
Brakes/Suspension
202
Sep 2, 2015 12:34 PM
08G37SBLUE
Jul 19, 2014 03:01 PM
NiTeHawKPwNeD
Dec 11, 2010 12:55 PM
Spaded21
May 17, 2010 03:55 PM
wcirksena
Mar 30, 2008 11:55 PM
