Help 2013 G37x battery issues
Old May 14, 2018 | 07:33 PM
Luke N. Yonash's Avatar
Luke N. Yonash
A while back I had a 5yr old battery that I replaced. I have a broken ankle right now, so the car is only being started occasionally. About a week after replacing the battery, I attempted to start it.... The doors would not unlock with the fob and had to use the mechanical key to open, even with the fob in it's "slot" none of the instrument panel lit up accept a steering wheel light and a couple other lights like that but the car would not start..even with a jump. I found a 140 amp battery fuse that was blown, so I have ordered a new one. But here is my question... If I replace the fuse will it happen again? If so, what causes that fuse to blow? I am hoping that when I replaced the battery I somehow shorted the fuse and that is why it blew. Has anyone else experienced an issue like this? Thank you for taking the time to read and respond.
Old May 15, 2018 | 09:04 AM
Baadnewsburr's Avatar
Baadnewsburr
the only time I've ever seen that is when someone hooked up the jumper cables backwards
Old May 22, 2018 | 01:21 PM
Surfnazi's Avatar
Surfnazi
You might have discharged remaining charge in system.when you took out old battery by accident
Old May 30, 2018 | 04:00 AM
Luke N. Yonash
Can you elaborate on this? What do you mean by "discharged remaining charge in system?"
Old May 30, 2018 | 08:12 AM
telcoman's Avatar
telcoman
It will blow again if you reverse the battery connections or cause a short circuit. That 140 amp fuse blowing will prevent a fire from destroying your vehicle.
Make sure you connect the replacement battery correctly.
Verify the polarity of the battery terminals with your multimeter.
Telcoman
gman69
Jun 17, 2016 04:30 PM
Newad
General Tech Questions
Aug 2, 2014 02:35 PM
PR_G37
TSB - Technical Bulletins
Aug 23, 2011 04:22 PM
Tribute
Aug 28, 2010 01:05 AM
