Installing Sub+Amp Questions
Old May 1, 2018 | 12:01 AM
BobbyKasoca's Avatar
BobbyKasoca
I've been looking on here and on youtube for a while to see how people connected their subs and amps to their cars, but I haven't been seeing much on how to approach this. What's the best way to go about doing this with the factory radio installed?
Old May 1, 2018 | 12:28 AM
Stachuu's Avatar
Stachuu
In a nutshell.. take line output from car stereo and feed it into an amp, from amp to the speakers that meet requirements of the amp.
Old May 1, 2018 | 06:01 AM
Surfnazi's Avatar
Surfnazi
There are tons of posts on how to do this on forum
Old May 3, 2018 | 09:28 AM
Landshark's Avatar
Landshark
tap into the front speaker preamp outs from the head unit at the amp connector in the trunk. use Posi-taps - make it very easy.
the front speakers are louder, rear speakers are just fill. you want the HU preamp out signal because the Bose amp will not have applied its crappy EQ to it.
Old May 3, 2018 | 10:12 AM
BobbyKasoca
and where should I get the power from To run to the amp? I was seeing people say that the factory amp doesn’t have enough power to turn on the amp
Old May 3, 2018 | 11:13 AM
Entcee's Avatar
Entcee
It doesn't. You will need to run a wire (gauge will depend on the wattage of the amp) from the battery to the amp. Be sure you use an appropriate fuse placed as close to the battery as you can.
Also, tapping into the front speakers (pre-amp) is a good method, but I found tapping the sub wires (before the sub amp) was better for me... for a couple reasons.
Old May 4, 2018 | 09:46 AM
BobbyKasoca
understood. Thank you, but I’m trying to avoid getting power directly from the battery. I’m not sure where I’d put the remote switch because I don’t want the speakers to be on when the car is off. You follow me?
Old May 4, 2018 | 10:02 AM
Entcee's Avatar
Entcee
You really won't have a choice. You need to get the power directly from the battery... unless the amp is only like 50 watts.
Here is a good guide that will show you what gauge power and ground wires you will need. https://www.crutchfield.com/S-B3dK5S...uge_chart.html
Some people have used pin #22 (for sedan at least) for the remote wire.
Old May 4, 2018 | 10:28 AM
BobbyKasoca
Yeah that’s right. sorry I confused myself, I was just stuck on the remote wire part. That’s why I made this thread I haven’t seen anyone post on where to connect the remote wire in their coupes.
Old May 4, 2018 | 10:38 AM
Entcee's Avatar
Entcee
If the wire from the factory amp will not turn on your amp, you just might have to run the remote wire to your fuse box.
Old May 4, 2018 | 11:19 AM
NealP's Avatar
NealP
There definitely is a thread on this. I know because that's where I got my info when I set mine up. I made all connections except power and ground to the existing amp in the trunk. Probably one of these:
https://www.myg37.com/forums/d-i-y-i...stall-diy.html
https://www.myg37.com/forums/d-i-y-i...er-wiring.html
https://www.myg37.com/forums/audio-v...l-finally.html
Old May 4, 2018 | 11:55 AM
BobbyKasoca
found what I was looking for, thanks!
Old Jul 7, 2018 | 01:57 PM
BobbyKasoca
Running into an issue
So I figured everything out, everything is connected and working except for one thing. No sound at all. I tapped into 23-26 and I’m getting no sound, however I’m getting power and everything. This is my third time trying and i cannot find a way to get sound. I even had a picture diagram to help guide me and still nothing. Anyone have any ideas?
Diode Dynamics
Lighting/Cleaning Products
127
Nov 30, 2021 02:20 PM
b2autodesigns
Wheel & Tires
507
Apr 5, 2018 11:38 AM
Budakai
36
Mar 30, 2018 11:43 PM
jabba_the_slut
Sep 20, 2016 10:58 PM
jcm707
Sep 18, 2016 09:47 PM
