Do I need to run new speaker wire?
Old Apr 17, 2018 | 09:31 PM
HotSawce's Avatar
HotSawce
So I'm throwing in some new components up front. I will be putting the 6.5" in the hole for our 10" woofer using an adapter and ideally, would like to reuse that woofer's speaker wire. According to bose, those woofers are currently receiving 70 watts and if the wire is noticeably beefier than that going to the other speakers ( still not sure what guage it is). I plan to be running 110 watts to my new speakers. If the factory wire is currently taking 70 watts, do you think 110 should be fine or do I NEED to re run new wire?
Thanks
Old Apr 18, 2018 | 12:25 AM
RA081224's Avatar
RA081224
Thanks
OK, you may be feeding them with a 110 watt amp but are they direct wired to the amp or are they coupled with a crossover network? Also, to be completely accurate, Id need to know the resistance of the speaker your using, the length run of wire between the amp and the speaker and the maximum voltage your amp will drive those speakers with to deliver the 110 watts
Old Apr 18, 2018 | 01:07 AM
Superjay's Avatar
Superjay
Thanks
that wire is 18 awg. it's perfectly fine to run up to 225 watts through an 18 awg wire. You'll certainly be fine with the factory wire.
Old Apr 18, 2018 | 02:50 PM
blazeplacid's Avatar
blazeplacid
The factory wire will work fine.
I went the hard way and drilled the molex, ran new wires, and spent about 8 hours carefully doing it.
Old Apr 19, 2018 | 08:51 AM
HotSawce's Avatar
HotSawce
How do you know it's 18 awg, you measured it?
Old Apr 19, 2018 | 10:17 AM
blazeplacid
You can pretty much eyeball it.
Its either 18ga or 20ga.
Don't get to caught up in the specs.
Music is very dynamic.
Old Apr 19, 2018 | 11:28 AM
Superjay's Avatar
Superjay
I've been employed professionally in the 12-volt industry for 28 years. It's my job to know this stuff. Also, the schematics say so.
Fishermr
Nov 4, 2016 02:01 PM
Tacoboy
Nov 16, 2015 11:22 PM
JakeG37
Jul 29, 2015 01:31 PM
mmnjtwa
Apr 17, 2015 02:08 AM
cjc357
Jun 3, 2011 05:27 PM
