Speaker wire question
Old May 26, 2011 | 06:42 PM
cjc357's Avatar
cjc357
I am hooking up a JBL MS-8 DSP with the stock 2008 G37S COUPE system.
two questions:
1: POST amp, can I find any full signal speaker wires. I need one full right signal and one full left signal. I am thinking the rear mids might be full channel speakers. Any thoughts? When I say full, I mean full range, not filtered down or cutting off any frequencies. If I had a probe I would be able to determine this myself.
2: My car is in the shop or I would check myself. Does the NAVI and Bluetooth audio come out of the center speaker or all speakers. I cant recall.
Old May 27, 2011 | 01:07 PM
bitNine's Avatar
bitNine
If you want full range, then you want pre-amp. Any speaker signal will likely not be full range. If you can't personally tell the difference between the two with your own ears, then what's the point of using a probe to test for it? Just don't amplify an already amplified signal (speaker level). It's like making a photocopy of a photocopy.
Seems to come out of front speakers, but I can't tell if it's coming out of the center speaker too.
Old May 27, 2011 | 02:53 PM
cjc357's Avatar
cjc357
bitnine - I need to make sure I have a full range signal not for my listening purposes but for the dsp. I hardly think most people can tell if say 80hz and below is being cut out from a 6 1/2 inch speaker, but of course a probe could.
I would tend to agree that it seems to make more sense to grab the signal pre-amp but I am being told directly from Gary Biggs of Harmon (JBL/Infinity) to grab the signal on my car post amp. Gary Biggs is the #1 premier car audio tech in the country. I will have to give him a call and have him clarify.
So I guess most people dont know if any of the post-amp speaker wires are full range. Again I was guessing if ANY are it would be the rear 6 1/2's in the side rear portion of the car.
Old Jun 3, 2011 | 05:27 PM
cjc357's Avatar
cjc357
Anyone anyone?
Simran Mann
Sep 13, 2015 01:51 AM
bingpwr
Sep 4, 2015 09:44 PM
Detailed Image
Lighting/Cleaning Products
Sep 4, 2015 08:14 AM
m3clubracer
Aug 31, 2015 01:59 PM
