2012 G37s Coupe Backup Camera problem
Old Dec 21, 2017 | 01:17 AM
aznviper37's Avatar
aznviper37
Recently my backup camera started having some problems whenever I close the trunk on my G37s. Whenever I close the lid and than use the backup camera the picture shows up snowy or with a lot of noise. Sometimes the picture is just black with the guidelines still present. This normally fixes itself after sometime but when I use the trunk again the problem happens again. Any idea what might be the problem?
Thanks
Old Dec 21, 2017 | 06:19 AM
The Pope's Avatar
The Pope
Loose connection (wiring)????
The first thing that I'd do would be to remove the inner truck lid liner and check the connection between the camera and the main harness.
Old Jan 30, 2018 | 08:09 AM
Sparkman's Avatar
Sparkman
Having similar issue. Did you figure out what the cause was, and a fix yet?
Old Feb 7, 2018 | 08:48 PM
beefychicken's Avatar
beefychicken
Try checking were the wires flex near the trunk hinge. i have a '14 and they travel near the left hinge inside a flexible conduit. IIRC my sons G35 wires routed near the right hinge and we had to repair those several times, but that was for the trunk release, no BU cams back then....
G37onbrembos
Dec 27, 2022 05:43 PM
Pirateflag
Aug 17, 2014 09:22 AM
zpieces
Sep 26, 2013 11:48 AM
SilverTL05
Jan 10, 2013 09:41 PM
hopgo
Buying & Leasing
Oct 1, 2007 10:58 PM
