2009 G37x Backup Camera Problem
Old Sep 24, 2013 | 01:26 PM
zpieces's Avatar
zpieces
My camera a little under 3 weeks ago started having an issue. The image appears distorted and lots of static. I ran the "self-diagnostic tool" in the hidden menu and all connections are OK supposedly. Any thoughts as to what might be causing this?
Old Sep 24, 2013 | 04:52 PM
SlimTV's Avatar
SlimTV
If its under warranty take it to the dealer. It looks like some kind of interference. Did you remove the camera or unhook any of the wires? Maybe a wire got pinched somehow? Possibly a camera wire is loose? Did you install an aftermarket system (sub & amp), if so check the wires you tapped into if any? Did you drill anything in your trunk area including a rear spoiler? Did anything along the lines of the camera and wiring get wet/corroded wires? I cant really think of anything else. The only time I've seen a camera do that is during an earthquake or when theres lots of movement or vibration or when the battery is about to die.
Old Sep 26, 2013 | 11:48 AM
zpieces's Avatar
zpieces
The warranty ended less than a month before this started happening. They want $140 just to look at it.... That's why I posted here first. I didn't do any meddling around there, no aftermarket installs, everything is stock. I was thinking it could be engine vibration but it happens on and off. I notice it mostly on hot/humid days. It works fine 50% of the time.
Chris Olson
Dec 29, 2025 07:59 PM
GXXXVII
General Tech Questions
Dec 11, 2021 08:58 AM
cacique_quique
Aug 26, 2015 07:38 AM
jessebritches
Aug 20, 2015 12:40 AM
