Easily add a fused circuit
Old Aug 5, 2015 | 02:45 PM
blazeplacid's Avatar
blazeplacid
I wanted to hard wire my Valentine 1 into my fuse box.
I previously ran a blend mount and the invisicord with my valentine.
I didn't want to spend $100 on a mount and a cord again.
Valentine includes a hard wiring kit, so I used it.
The fuses that are used in the interior fuse box are low profile fuse and aren't as easy to add a circuit like older (larger) fuses.
I found this on amazon
Amazon.com : FAST Shipping* ADD CIRCUIT BLADE STYLE APS ATT LOW PROFILE MINI FUSETAP FUSE TAP + FUSE SET 5, 7.5, 10, 15, 20 AMPS : Car Electronics Amazon.com : FAST Shipping* ADD CIRCUIT BLADE STYLE APS ATT LOW PROFILE MINI FUSETAP FUSE TAP + FUSE SET 5, 7.5, 10, 15, 20 AMPS : Car Electronics
It made the install very smooth and very easy.
You essentially remove the existing fuse.
Then you insert the removed fuse into the fuse tap.
Insert the new fuse and you are ready to go.
I used the cigarette lighter fuse. I very rarely use the cigarette/accessory port so this won't cause any issues.
Here are some photos showing how easy the install was .
Original fuse box
Fuse tap installed
Fuse box closed... No buldges or awkward wiring sticking out
Old Aug 6, 2015 | 01:49 PM
meme405's Avatar
meme405
I used these to add my dash cam as well. Very good.
Just make sure to use the same size fuses, AKA don't upsize a 10amp to 20amps. Your asking for trouble otherwise.
Old Aug 6, 2015 | 02:12 PM
i heart ricers's Avatar
i heart ricers
Original fuse box
Fuse tap installed
youve never seen these before?
heres 10 for $30
http://www.ebay.com/itm/10-ATM-Mini-Fuse-Tap-Add-on-Dual-Circuit-Adapter-Auto-Car-Audio-Terminals-/191194993919?pt=LH_DefaultDomain_0&hash=item2c841c14ff
Old Aug 6, 2015 | 04:32 PM
JSolo's Avatar
JSolo
Just say no!!!!!
^^Those won't work. They're mini, but not mini low profile.
Old Aug 6, 2015 | 06:07 PM
defektion's Avatar
defektion
Do you know what amp you used?
Old Aug 6, 2015 | 11:45 PM
Epiphany's Avatar
Epiphany
Yes they will, I have one hooked up to my dash cam out of my old car. Just your regular ATM fuses.
Old Aug 6, 2015 | 11:51 PM
JSolo's Avatar
JSolo
Just say no!!!!!
^^My comment was directed at i heart ricer's ebay link. The OP has the correct fuse in the amazon link.
Old Aug 7, 2015 | 12:27 AM
Epiphany's Avatar
Epiphany
I was also talking about the ebay link
Old Aug 7, 2015 | 12:36 AM
JSolo's Avatar
JSolo
Just say no!!!!!
The ebay link is for ATM mini fuses. The g37 takes ATM mini low profile fuses. How are they the same?
Old Aug 7, 2015 | 01:08 AM
Epiphany's Avatar
Epiphany
The only difference between them is the height, so why would they not work? It's been working fine in my car since about 2 hours after I brought it home.
Old Aug 7, 2015 | 08:13 AM
i heart ricers
i think you are confused
they will work i have them and have always used them
get on ebay and amazon again ther are tons and are about $3-$5 each
Old Sep 16, 2015 | 06:57 PM
Christopher Dye's Avatar
Christopher Dye
Batt fuse
I see that there's one fuse tap however shouldn't there be 2? One has to draw power from a batt fuse. I was wondering which batt fuse was used.
Old Sep 17, 2015 | 10:50 AM
blazeplacid
You only use one fuse.
The purpose is to add a fused line.
You don't want to exceed the current draw the factory wire is sized for.
Amaadkhan2k
Oct 4, 2024 01:20 PM
vamarris
Dec 9, 2018 11:10 AM
Kojack
Oct 9, 2015 05:53 PM
stm37s
The M - Spot
Oct 1, 2015 06:53 AM
