Powered 10in sub in g37s coupe
Old Apr 29, 2015 | 03:50 PM
My37s0805's Avatar
My37s0805
I have a 2008 G37s coupe and would like to add a little extra bass to my Bose system. Im keeping the stock screen I have which also has nav if that matters and stock speakers. Was wondering if anyone has done something simliar by adding a 10 or 12inch sub. I was also reffered to this powered sub provided in link below. What do you all think and do you think this would be a hard install? Never worked with audio btw.
http://www.ebay.com/itm/Infinity-BassLink-200W-10-Class-D-Powered-Subwoofer-System-w-Free-8gu-Amp-Kit-/301594773958?pt=LH_DefaultDomain_0&hash=item46387309c6&vxp=mtr
Old Apr 29, 2015 | 04:57 PM
Rybitron's Avatar
Rybitron
Infinity Basslink 200W 10" Class D Powered Subwoofer System w Free 8GU Amp Kit | eBay
I used to work at Best Buy and we sold that infiniti basslink. It will be better to go with a "normal" sub and amp combo than the basslink.
As far as installing you will need to run power wire from your battery to the amp in the trunk (that you will buy). You will also need to install a line out converter which taps into the signal going to your speakers and converts it to an RCA connection that will connect to your amp. Best Buy should charge about $110 total for install.
There are sub boxes made for the G37 here is a link to a couple, but there are more.
2008-13 Infiniti G37 sedan custom subwoofer enclosure speaker box
Custom Sub Enclosure | Affordable Sub Box
Old Apr 30, 2015 | 08:54 AM
Ryne's Avatar
Ryne
The Steering Wheel Guy
I also previously worked at Best Buy for what that's worth, lol.
I have also had experience with the Basslink firsthand in my previous car. I was very happy with the output and sound quality. I have had many different subwoofer orientations: 2-12" woofers, 1-12" woofer, 1-10" woofer, and the Basslink. The Basslink adds a perfect amount of bass to compliment the factory system in a small package and the install is very simple and straightforward.
You will not have King Kong in your trunk if that is what you're after though.
Old Apr 30, 2015 | 01:00 PM
Rybitron's Avatar
Rybitron
We did have a guy put 2 of those in his trunk that turned out pretty well, and considering that ebay price, might work out.
Old Apr 30, 2015 | 03:31 PM
Magowin's Avatar
Magowin
I had a basslink in my Celica GTS and Del Sol was always impressed by the sound of it. I actually gave it to my brother because I never used the high input connector and lost it so couldn't use it in the G. I always used rca input jacks.
Old Apr 30, 2015 | 08:50 PM
ddnorby's Avatar
ddnorby
I added a 10" Pioneer Champion series subwoofer ($50 amazon) that i pieced together myself with a matching pioneer amp ($100 amazon) and a sealed enclosure. It sits in my trunk and once i dialed it in, adds the perfect amount of bass but I can turn it up or down as needed through the head unit. The existing Bose system was pretty good IMO, just needed a little extra punch.
Lt8Che
91
Apr 8, 2022 04:55 PM
Thedbarz
33
Feb 9, 2016 12:05 AM
BANNISTER
Dec 10, 2015 04:14 PM
joeposter
Sep 8, 2015 04:36 PM
