Cigarette outlet doesn't work
Old May 8, 2016 | 04:24 PM
Vj_G37xS's Avatar
Vj_G37xS
Hi All, (I have a 2012 g37xS)
Apologies for the bump but I'm having the same issue where both the arm rest and one near the shifter are not working. I checked the fuse box near the footwell but can't determine which one is the fuse for the cig ligher. I showed the stealership last time I went in to get an oil change and they said I'll need to replace the fuse box. I think that sounds a bit drastic, no? Does anyone know which in the picture I took of the fuse at the footwell the cig lighter is? I checked under the hood and nothing seems to reference the lighter.
Old May 8, 2016 | 05:10 PM
stealthee's Avatar
stealthee
I don't own a G yet, but my guess would be the one that says socket.
Old May 8, 2016 | 05:23 PM
Vj_G37xS's Avatar
Vj_G37xS
Thanks 'Stealthee'...I too figured that was it after reading up some more. But the fuse I pulled out looks to be good and not broken. Just in case I still changed it with the space and still not working
Old May 8, 2016 | 05:34 PM
telcoman's Avatar
telcoman
Have you tried the FSM?
http://www.nicoclub.com/FSM/G37/Sedan/2012/PG.pdf
See page PG-17
Use a meter and check for voltage at connector M-132 terminal 2
Telcoman
Old May 8, 2016 | 10:47 PM
Vj_G37xS's Avatar
Vj_G37xS
Thanks for the link 'telcoman'. I just bought a digital meter today and I'll give it a shot tomorrow after work. Update to follow...
Old May 9, 2016 | 12:43 AM
antirice's Avatar
antirice
That's weird. I have a 2010 sedan. Mine has one for the Cig Lighter and a separate one for the power socket (which I think it's the one inside the center console). Maybe coupe is different than sedan.
Mine looks exactly like this one:
Old May 9, 2016 | 12:50 AM
I'm pretty sure it's the one that says 20A socket
Old May 9, 2016 | 01:54 PM
Kris9884's Avatar
Kris9884
Interesting, I've never used that one, mine could be broken too as far as I know. I hate wires so I use the center console one and have my charger cable come out of the back in between the passenger seat. I don't see it unless I want to, far more clean this way.
Old May 9, 2016 | 03:05 PM
Vj_G37xS's Avatar
Vj_G37xS
*Update*
Thanks All !!
Turns out I had to replace the "20A Socket" fuse a few times before one worked (weird how the others were bad but didnt look it) and the meter testing passed too
was getting frustrated so I even went and removed the console (thanks to nicoclub.com link by telcoman) to see if the cable was loose just before the last fuse replacement.
Still not sure why Infiniti decided to write 'Socket' instead of 'Cig Lighter' oh well... glad I didn't go to the dealership and replace/pay for parts I didn't need.
Old May 9, 2016 | 05:26 PM
stealthee's Avatar
stealthee
Because most manufacturers don't even put lighters in the car anymore and they are really nothing more than a power socket any more.
Old Dec 22, 2017 | 03:58 PM
EBO-Infiniti's Avatar
EBO-Infiniti
SAME HERE; MY FIX, Both the fuses needed to be changed in G37 10'
I had this problem for a long time with 2010 G37 then one day I went in with a tester. The fix was I had to change both fuzes: Cigerette Lighter and Power Socket.
Seemingly if the power Socket is blown then they both go out. But it is possible for the power socket ( in arm rest) to work without the cigarette lighter if only the cigarette lighter is blown.
Old Aug 10, 2019 | 09:50 PM
Ben Shaw's Avatar
Ben Shaw
Fixed!
So jus in case anyone else is having this problem. My lighters and power socket stopped working I changed the fuse 20A called "Socket" even though it wasn't blown and it still didn't work. However I found the 10A "elec parts batt" was blown. Changed it and everything is working now.
Old Oct 21, 2023 | 04:51 PM
Cooldude61's Avatar
Cooldude61
Fixed my Cigarette/ power outlet.
My 2013 G37x sedan had the same cigarette/ power outlet problem. The diagram only showed the one for socket checked that and it was good. The storage compartment worked so thought it might be corrosion on positive tip. Attached a small grinding stone bit gave it a one second contact, and the outlet works again.
Old Oct 21, 2023 | 04:55 PM
  #29
Cooldude61's Avatar
Cooldude61
Same on 2013 G37x
I have the same diagram. The one that says socket is for the outlet in the storage and in front of the shifter.
BigPurp
General Tech Questions
Jun 22, 2025 05:34 PM
Rag7
31
Jan 18, 2022 05:52 PM
GXXXVII
Dec 11, 2021 08:58 AM
Gillan
Sep 27, 2021 02:03 AM
finagle69
Jul 2, 2008 07:21 PM
