Cigarette outlet doesn't work
Old May 24, 2014 | 11:07 PM
R.I.P. Grandma's Avatar
R.I.P. Grandma
Hi there,
I recently acquired an 08 G37S and have the dreaded issue of the cigarette outlet not working. I checked all the fuses on the driver side by the pedals and the fuses all seem to be fine. I also checked the fuses next to the battery and they are fine as well. I'm hoping someone might be able to shed some light on what else I can check as I was hoping to avoid bringing the car into a dealer and have read through search that many people have reported bad fuses as the culprit, but that doesn't seem like the issue on this car.
Any help would be appreciated.
Thanks!
Old May 25, 2014 | 08:18 AM
monytx's Avatar
monytx
Meh, I'd disconnect the battery, or take the cig lighter out and plug it back in..
Old May 25, 2014 | 10:09 AM
dkmesa350z's Avatar
dkmesa350z
fuses can be blown even if they do not appear to be. I would refer to the owner's manual to determine which fuse goes to the outlet and replace it. If that doesn't work, I've heard of replacing the outlet...which I'm sure is relatively cheap.
Old May 25, 2014 | 02:13 PM
R.I.P. Grandma
Thanks for the feedback. I've replaced the outlet fuse as a precaution and it still doesn't work. I spoke to a dealer and they noted it was a known issue where they just replace the unit. I'd love to repair this myself if possible, but I also don't want to take the the pieces around the shifter out to see if it's a connection problem. All the other electronics work, so this is the only issue.
Old May 25, 2014 | 05:27 PM
monytx's Avatar
monytx
Okay, have you tried replacing the fuses? I know you said they weren't bad, but as dkmesa350z said, fuses can be blown and not have any signs. You can get a tester and see if it's completing the circuit. Or just change out the fuse. You should have some spares in the fuse box already.
Old May 26, 2014 | 07:22 AM
R.I.P. Grandma
Yes. I replaced the fuse for the outlet, but it still doesn't work.
Old May 26, 2014 | 08:57 AM
Azngonkick's Avatar
Azngonkick
your other option could be going to any electronic store (even walmart), and buying one of those that plug into any outlet (the one in your center console) and turning into a dual outlet or more.
Old May 26, 2014 | 09:49 AM
R.I.P. Grandma
Agreed, but ideally I'd like to get this issue resolved. Will consider having the dealer troubleshoot after trying to check more fuses.
Old May 27, 2014 | 12:02 AM
deadlocked's Avatar
deadlocked
Probably fuse is blown
Old May 27, 2014 | 07:46 AM
Paratrooper's Avatar
Paratrooper
He said he replaced it..
Op, whenever you replace the fuse and you got to plug anythign in, are you hearing any kind of pop sound, double check that the new fuse isnt blown as well, though Im sure you already have..
Old May 27, 2014 | 10:34 PM
R.I.P. Grandma
Appreciate the recommendation. I don't hear any pop and the replaced fuse seems to be in good order. I'd be more concerned if other electronics were impacted, but at this point it's just a bit frustrating that it's not a simple fuse replacement fix. I might try to disconnect the battery over the weekend, but frankly I'd be shocked if that resolves the issue. I'm wondering if aside from a simple fuse change if there is any other way I can attempt to troubleshoot the issue, maybe someone else had a similar experience?
Old May 29, 2014 | 05:22 PM
infinitiman96's Avatar
infinitiman96
Is it possible the lighter isnt connected? I've seen people wire aftermarket electronics to cigarette lighters before. Since you're not the original owner of the car, check to make sure the wires are indeed connected behind the lighter itself.
Old May 30, 2014 | 01:12 PM
rmfnla's Avatar
rmfnla
Sounds like a break in one of the wires.
You need to trace the lines with a circuit tester...
Old Apr 17, 2015 | 03:15 PM
wlmmn's Avatar
wlmmn
Sorry to bump an old thread but I have the same issue with neither cigarette lighter charging my iPhone, whether it's the one by the shifter or the one in the armest compartment (the iPhone charger's LED light doesn't even come on, and it works in other cars so it's not a bad/broken charger).
I just checked the manual on where the two fuse boxes are located: the one by the driver's footwell and the other under the hood. Neither diagram on either fuse box mention which one the cigarette lighter is. I haven't pulled any fuses yet 'cause I don't even know which one it is. I just came back from the Nissan parts department (they're close to my home, as opposed to the Infiniti dealer miles away) and the guy said there should be another diagram that's by the steering column that has relays and a much bigger, more descriptive diagram that should tell me which fuse the cigarette lighter is, but I don't see anything like that. Are both cigarette lighters controlled by the same fuse? If so, which one is it? If not, which two are they?
Didn't think this would be this difficult. Oh, and I'm aware that the lighters don't charge anything when the car is off.
Old Apr 21, 2015 | 08:10 PM
wlmmn's Avatar
wlmmn
So for whoever might read this, my cigarette lighter issue was under warranty so I took it into the dealership. They said it was a fuse issue, and replaced it under warranty; it works now.
