NEED HELP/Back up sensors stopped working
Old Apr 21, 2014 | 10:38 AM
Vance67's Avatar
Vance67
So I have a 2010 G37S Coupe RWD 6MT
Yesterday I went to visit a friend in the hospital and if that wasn't bad enough the hospital only has valet parking. So I had the valet take it, who couldn't find reverse and i had to instruct him where it was. This is understandable because not every manual has reverse in the same place.
When I got into the car, I checked the gears (and the entire car) and backed up to a pole, which is when I realized the sensors didn't pick it up. I tried again against a car and nothing. Realizing I had no proof that they worked before I took off hoping it was just a cable that came undone and an easy fix.
This morning I when I left my garage, the back up sensors were working again. Last night, when I came home I pulled into my garage and put the car in reverse, no back up warning from the sensors.
So good news they are working, but it does make me feel nervous that at one point they weren't, maybe I wasn't close enough to the car or the pole was in a blind spot, but it didn't work in my garage last night.
So I was wondering if anyone else has had this issue or any ideas on what it could be. Is it the start having to have some part of the sensors replaced.
I apologize for the long winded explanation, but any help is appreciated to put my worries to rest.
Thank you
Old Apr 21, 2014 | 12:30 PM
rmfnla's Avatar
rmfnla
Intermittent electrical problems; sounds like an English car...
Old Apr 21, 2014 | 01:03 PM
blackfunk's Avatar
blackfunk
Nah, I've had this happen on other cars as well. If the pole is too close to the car the radar won't find it. Try it at a more solid object.
Old Apr 21, 2014 | 04:36 PM
ai3j50's Avatar
ai3j50
Also check the sonar switch on the left side near the trunk release button. Possible the switch is between on and off.
Old Apr 21, 2014 | 05:59 PM
Vance67's Avatar
Vance67
Oh ya, I forgot about that button
Old Apr 15, 2015 | 11:06 PM
Cjrodriguez31's Avatar
Cjrodriguez31
Im having the same problem.
Except mine has the blinking yellow light on the switch and when i go into reverse it wont even sense my friend standing right behind the sensors.
I have already gone through the screen diagnosis and everything seems to be fine. I was rear ended but i know the body shop will have no clue how to fix it if i bring it back.
I have a video so you can see what i mean.
http://youtube.com/oXAs-gPy4Mg
Old Jul 2, 2019 | 09:27 PM
Etiennear's Avatar
Etiennear
Did you fix the problem?
Old Jul 3, 2019 | 11:58 AM
slartibartfast's Avatar
slartibartfast
I don't know to whom you are addressing your question but the last two posters haven't written anything on this board since 2016.
Old Jul 3, 2019 | 12:47 PM
Etiennear's Avatar
Etiennear
To anyone who found a solution
Old Jul 3, 2019 | 01:30 PM
ILM-NC G37S's Avatar
ILM-NC G37S
Without a good scan tool to pull the codes from the sonar system, there is no way to know what the problem might be. A OBD2 scanner may or may not work- if it reads the K-Line, then maybe. It could be a bad wire, sensor, module, anything.
Per the FSM, there is no "at home/self-diagnosis" feature. The most you could do is check the wiring for any obvious problems. More than likely you have a bad sensor, but can not say for certainty- nor which one...
Old Aug 16, 2019 | 08:49 PM
kicksdechris's Avatar
kicksdechris
just got rear ended today at about 5-7mph. sensor button is flashing yellow since the impact. not a lot of damage or alignment issues just no functioning rear sonar for the moment.
hdm20
General Tech Questions
Oct 13, 2014 07:23 PM
ZiadR
Jun 11, 2012 08:40 PM
thholr
Feb 1, 2012 10:04 AM
The_xeroxman
Sep 5, 2010 01:30 PM
eksigned
May 16, 2010 08:44 PM
