Finally some inspiration for that next mod
paratrooper i love your thread! i want to do what you were planning and relocating the screen to my sunglass holder. if i just want to relocate the unit up top with the stock screen is it just one cable that i have to run or are there a lot of different connections? i have a 2013 non nav journey.
does anyone know if the sunglasses tray above are all the same for the coups and sedans. i see them on ebay for 08 and 09 models i dont know if they will fit the 2013 models.
Mine and your sunglass holder should be the same, and if your relocating then your looking at extending a wiring harness, with a butt ton of small gauge wires. Other than that it shouldn't be too hard.
When I saw the Nexus at walmart, it was kind of awkward for the employees as I was making them unbolt it from the security display so I can measure it with my tape measure.. lol
Of course I purchased through Ebay for a slightly used one.
I installed a charged 7 port hub with easy cap that rca thing spliced in and a USB DAC into the xm sat radio. Worked great. The backup camera worked great with dashcam app. I had charging issues (lost charge while screen was on) so I went back to stock.
I just bought a DC DC buck which I'm hoping will help with the charging issue.
Will post back with pics
My setup....sorry for the shaky video
G37 2012 + nexus 7 2013 w/ Timur
This is awesome stuff you guys have come across. You can take this a step in a different direction for an aftermarket radio. The new metra kit is garbage and is cheap looking. The new Alpine Media unit should be an almost direct bolt up to the replacement screen, just a tad deeper. Wire the stock screen into the AV-IN of the unit, and the rear cam into the rear cam input. Alpine iLX-007 Digital media receiver with Apple CarPlay? at Crutchfield.com
I know this thread has been sitting idle for a bit, but I am very interested in trying something like this. First noob question, does it matter that it is a Nexus 7 tab, or will any 7" Android tablet work? I can get a new Galaxy Tab for the same price as a "referb" Nexus 7.
Also curious on what the long term results are. Paratrooper, any buyers remorse a couple years in?
By the way I have a 2011 Journey non-nav
Depends on what your goal is. One of the main benefits of getting the nexus 7 2012 or 2013 is that you'll be able to load the custom ROM on it. The benefits to this is that when the car is turned off the tablet will go into a deep sleep automatically and when the ignition is turned on the tablet will wake up as well as you'll be able to use OTG cable to connect power and an external USB hub. also the method outlined has been proven to work with our cars, I myself have this setup in my 2012 Journey non navigation.
Yes, i did setup that way. Honestly the only thing i recommend is that you read the step by step multiple times and that you make sure you have everything you need for this project before you start and plan on having your center console disassembled for 1 to 2 days. other than that, good luck.
Can you point me to which step-by-step you followed? I found one here but it seems pretty fragmented. Did you find a succinct one?
Here is my setup and parts:
Required in order to have indash car-puter
2012 or 2013 Nexus 7
Timur's USB Host kernel for the nexus 7, you will need to root the tablet and install SU in order for this to work.
OTG cable
2.1 Amp charger, i am using a 3 port car charger
4 port usb hub
Micro USB charger cable 6 ft
USB female -male, 6 ft
some sort of ribbon to hold the tablet in place
Display stock screen on tablet
WEIYA CV-04 - will need the plastic connector
FEBON 100 UVC Grabber Card (usb RCA version, the hdmi version is not worth it)
RCA male to male cable
Audio from the table to Car system
iSimple IS31
BestKits BAA3637
