Calling nav swappers
Old Jan 3, 2020 | 12:00 PM
  #46
ILM-NC G37S's Avatar
ILM-NC G37S
The confusion is that during playback, UP skips to the next station/track and DOWN is previous...,BUT, when scrolling through a station/track list, UP is previous while DOWN is next.
Old Jan 3, 2020 | 12:08 PM
  #47
dookie's Avatar
dookie
Got it. I was probably overthinking it... Although I hate it when software devs aren't consistent (note: i'm a SW dev)
Old Jan 3, 2020 | 02:50 PM
  #48
dookie's Avatar
dookie
Not sure how much help I can provide as I have a 2018 steering wheel, but, looking over my notes there are only three (3) wires going from the headunit to the steering wheel switches:
You may want to double check that you have those three (3) wires in the right place.
HOWEVER, as was mentioned previously, you should have a 2010+ preset switch assembly ("faceplate") to match your headunit. This could be the cause of your issues. I doubt your steering switches are the problem as, like I said earlier, I have a 2018 steering wheel and those switches work fine with the 2014 headunit.
Also, UP is for the NEXT track, DOWN is for previous. Always been this way AFAIK.
Re-examing the wiring diagram, the Vol up/down phone, and back buttons are all on the same wire going into the av control unit. (pin 16 on both the 07 M80 and 2010 M208 connectors). I wouldn't be surprised if I have a wiring issue with pin 16. Going to have to go disconnect everything and check the output.
Old Jan 3, 2020 | 03:57 PM
  #49
ILM-NC G37S
Sounds like you are on the right track. All it takes is one wire....
Old Jan 3, 2020 | 06:46 PM
  #50
dookie's Avatar
dookie
I fixed the issue with the steering wheel controls. There was a pin that wasn't seated properly... pin 16. all SWCs are good.
Old Jan 3, 2020 | 07:59 PM
  #51
ILM-NC G37S
Glad you got it sorted!
G37sTimCA
May 14, 2015 03:58 PM
aktif8
Nov 6, 2013 02:25 PM
Title101
Jun 10, 2013 12:13 AM
Bishamoten
Jun 7, 2013 07:13 PM
Graphite_G
Jul 29, 2012 12:02 PM
