Illuminated Kick Plates
Old Jan 15, 2013 | 09:18 PM
fgxmfmq's Avatar
fgxmfmq
I just purchased a 2008 g37s and it had the illuminated kick plates in there. My issue is this, the driver side not all the letters illuminate, if i tap it more light up, the passenger side is fine. I am wondering if this is a loose connection or if the led strip is bad?????? i am hoping that its something minor or do I have to replace the drivers side????? any help would be greatly appreciated! I am loving this vehicle so far
Old Jan 15, 2013 | 09:49 PM
OB G's Avatar
OB G
if you're tapping it and it comes back on then it looks like there's a loose led. try taking off the kick plate and reconnecting the led. i don't have the kick plates myself so i don't know exactly how it work.
Old Jan 15, 2013 | 10:19 PM
Gio37's Avatar
Gio37
Maybe this LINK will help
g/l
Old Jan 15, 2013 | 10:28 PM
mrcool007's Avatar
mrcool007
g/l
This can also mean that the grounding point chosen was bad, try relocation of the ground point
Old Jan 15, 2013 | 10:29 PM
Kevalteam's Avatar
Kevalteam
^ LOL I was looking forward to seeing a link to a fix not my DIY~
Talk to the dealer if this is covered?
OR
Maybe you can remove the bad side, check the connection, if the connection is good but the light is out|ask some local shop to check the led and have them replace it with a new led? or look used one on ebay or on here.
Old Jan 15, 2013 | 10:31 PM
Kevalteam's Avatar
Kevalteam
If the grounding was bad.....I am thinking both sides should not work.
Old Jan 15, 2013 | 10:38 PM
Gio37's Avatar
Gio37
I would remove the kickplate and check the connection....using the DIY link
Old Jan 15, 2013 | 10:39 PM
mrcool007's Avatar
mrcool007
Has a solution, disconnect the kick plate and run wires direct to battery and test that way to see if all lights come on, if so there's a bad point connection when installed in place....if light still does not operate fully then your kick plate has malfunctioned, investigate LED
Old Jan 16, 2013 | 08:32 AM
fgxmfmq's Avatar
fgxmfmq
I greatly appreciate all of your suggestions, i will try it this evening and let you guys know how it worked out.
4DRZ
May 29, 2024 09:28 AM
misc
29
May 24, 2023 03:57 PM
timc00k
Feb 15, 2017 09:15 AM
ANMVQ
Dec 8, 2016 04:55 PM
