Playing music from a flash drive
Old May 21, 2011 | 12:24 AM
gam1's Avatar
gam1
Question Playing music from a flash drive
I downloaded my i tunes library to a 16gb flash drive and it will not play in my car. I have a 2010 g37 sedan no nav. Is it a certain file I need? Help Please!!
Old May 21, 2011 | 04:54 PM
Dieseldoug22's Avatar
Dieseldoug22
I'm not sure about the 2010's but the 2008 I have you can only use a Compact Flash of 2GB. any more and it can't read it and the files are mp3's.
Old May 21, 2011 | 05:03 PM
hollywhip's Avatar
hollywhip
It won't play Apples music format M4a either convert them to MP3's or just download MP3's from now on.
Old May 21, 2011 | 05:18 PM
gam1's Avatar
gam1
Thanks, I will try that.
Old May 21, 2011 | 06:48 PM
Mudgen's Avatar
Mudgen
FWIW, I use a Coby 4Gb mp3 player. Works great, turns off when I turn the car off, comes back on at the exact instant of the song it was on when restarted. 2011 sedan, no nav.
Old May 21, 2011 | 09:19 PM
Fezzik's Avatar
Fezzik
You got it. and if you get the albulm info on there you can sometimes get the albulm art
Old May 23, 2011 | 10:55 AM
Jayhawk815's Avatar
Jayhawk815
He would have the usb flash drive port. I believe they changed that in either 2009 or 2010. And as far as size goes on the Compact Flash, it's limited on the amount of songs, not size of the compact flash. My 4gb compact flash works fine on my '08.
Old May 23, 2011 | 02:46 PM
1BadAssG's Avatar
1BadAssG
I bought a 16gb flash drive which is still in mail for my 2010 sedan. I'll update when I get it.
BTW only 2010+ has the usb. I had an 09 and it was compact flash but never tested.
Old May 24, 2011 | 11:02 AM
roots4x's Avatar
roots4x
You should be able to play aac files through USB if you have an actual USB port. Do you possibly have your files in Appl lossless format?
Old May 26, 2011 | 11:14 PM
matchan's Avatar
matchan
It does play *some* mp4 audio files. A few months back I was doing some testing and 1/10 mp4 files successfully played. I could not figure out why that one worked when the others did not ..
Xvid movies play nicely from the flash drive
Old May 27, 2011 | 12:44 AM
Morrissey's Avatar
Morrissey
Try another flash drive
Old May 27, 2011 | 11:57 PM
SimpsonTide985's Avatar
SimpsonTide985
I use a 16GB Kingston right now.
kavcheung
Jan 22, 2016 02:40 PM
claudiohv
Sep 17, 2015 01:43 AM
RexHavoc
Sep 6, 2015 01:03 AM
