Does the Center Channel Play Music?
Old Jun 14, 2010 | 06:55 PM
ufmike316's Avatar
ufmike316
I just got my 2010 G37S premium/Nav. When i play DVDs, not all of the sound plays. What should be coming out of the center channel is missing. It sounds like there is nothing coming out of the center channel with DVDs, IPOD, XM, CD, anything. Even when i use voice commands, i cant hear anything. Can anyone confirm if anything plays out of the center channel?
Old Jun 15, 2010 | 08:09 PM
ufmike316's Avatar
ufmike316
bump. i would really appreciate any input anyone has on if the center channel is supposed to work.
Old Jun 15, 2010 | 11:13 PM
SM_Shadowman's Avatar
SM_Shadowman
Are you talking about the center speaker on the dashboard? Yes, that is supposed to output sound.
The Factory Service Manual identifies that as the "Center Speaker":
•Outputs sound signal from BOSE amp.
•Outputs high, mid and low range sounds.
It seems to indicate that the nav voice guidance only outputs through the LH and RH speakers, although I may be misreading that. But there certainly should be sound coming out of the center in-dash speaker for your music and everything else.
Old Jun 16, 2010 | 07:11 AM
ufmike316's Avatar
ufmike316
thanks. mine has no output, so it must not be hooked u or is broken. ill have to take it in.
Rybitron
Nov 18, 2015 03:11 PM
delfinparis
Oct 8, 2015 06:06 PM
G37sPhoton
Oct 4, 2015 11:08 PM
butwhatuptho
Oct 4, 2015 07:51 PM
k19g37x
Sep 29, 2015 02:46 PM
