OBD II Cable Installation
Old Jun 11, 2010 | 03:03 PM
EnfinitI's Avatar
EnfinitI
I am going to be pursuing a CarPC and plan on having an OBD II cable for real time monitoring connected at all times.
I was wondering what other people have done to keep the cable out of the way of your legs and from falling out of the socket.
I also wanted to know if anyone has used a OBD II splitter or some such so that you can use the cable and still allow stuff to be plugged into the OBD II port if necessary.
Thanks!
Old Jun 11, 2010 | 03:15 PM
Modme's Avatar
Modme
2 screws hold the bracket for the OBD socket. Unscrew it and you can push the cable up into the dash.
Old Jun 11, 2010 | 03:29 PM
EnfinitI's Avatar
EnfinitI
After doing that did you remount the port somewhere up where you pushed it or did you zip tie it down?
Thanks for the reply, yet again Modme
Old Jun 11, 2010 | 05:07 PM
RedG37SNC's Avatar
RedG37SNC
I used a right angled OBD2 connector on a OBD2 cable extender because I didn't like it coming down so far, no need to unscrew it. Tie wrapped it to keep it from bounching off. Routed the cable under the console, connected the Access Port dongle and ran the USB cable up to the left side of the steering wheel console for easy access.
Thedbarz
33
Feb 9, 2016 12:05 AM
BANNISTER
Dec 10, 2015 04:14 PM
OBG37
Aug 27, 2015 03:56 PM
cparise
Aug 19, 2015 01:51 PM
goredcar
Aug 4, 2015 09:03 PM
