Use a smartphone in place of iPod?
I'm getting a smartphone soon (HTC Incredible or EVO 4g) and I would like to use that as an iPod in the car. The iPod classic I had died and I don't want to spend extra on an iPod if the phone can do it, since the phone will be my music player as well.
Apple have a special iPod protocol which the car understands. Is this documented? Since the 2010 G37 uses a usb connector, I'm thinking another device can act as an iPod if it implements it and then I can use the phone with an app.
There are a number of posts about this.
The G supports the Apple AiR mode, which is capable of advanced ipod remote control functions.
It also has limited support for USB mass storage devices. There are a number of limitations there, such as maximum partition size of around 60gb, and some have had issues with re-scanning mass storage devices when they add or remove music.
If you have the premium package you should have bluetooth A2DP support though, which most new phones support. There have been issues with skipping which seem related to signal strength, but I've used my Nexus One over bluetooth without any problems for music.
USB and A2DP don't give me the nice iPod interface which is what I want. I think what I'm looking for is an app that implements Apple Accessory Protocol - nuxx.net, and uses it with the smartphone player.
I'm sure Apple will have a lawsuit somewhere, even if they have no legitimate grounds for it, they'll try to squash it somehow. That said, yup, it would be cool.Trending Topics
The simplest answer is: the iPod adapter is a cable, the cable sends data/commands to the iPod via a serial port connection. So unless you want to code up an App for Android (easy enough) and then figure out the hardware portion of this communication (hard), its not going to happen.
I've played around with the iPod adapter in my 08, got it talking to my laptop ( for more info read HERE ) This can't be done on a phone like yours without some hardware hacking... some USB host kernel hacking...then USB to serial conversion... its a freaking pain, trust me.
What I do have right now is a cheapo BlackBerry Audio Gateway that connects to the AUX RCA jacks and streams music from my Droid (but no steering wheel controls), read HERE
Now, about the ANYCOM FIPO thing... thats quite interesting, not sure how I missed it before. Looks like it supports Bluetooth AVRCP profile, and so does Android... I'm going to order one today and give it a try (not holding my breath for steering wheel controls but we'll see).
I'll give it a go anyway, ordered already placed.
Mozy, I read that that Anycom does not support EDR (enhanced data rate) bluetooth and therefor samples down the bitrate of the audio so it sounds kinda crappy. Mozy hope you have good results. Please report back!
Also if you connect via BT to the anycom, can you still connect to the car via BT for phone calls? They are two different BT proticals just not sure if my Incredible will do that. Any ideas?
