Quick Navi question
Old Apr 21, 2010 | 11:43 AM
08Gsmith25's Avatar
08Gsmith25
Quick Navi question
I purchased my G used and it is programmed to the New England area, so I cant really use the Nav much other than just to view where I am/am going. Also, the time is stuck on the wrong time (I have my time zone and daylight savings settings correctly changed).
Do I just do the "press down the OK button for 15 seconds" method to fix this? thanks
Old Apr 21, 2010 | 12:41 PM
Chekov's Avatar
Chekov
Senior Citizen
First you need to change the region. Push DEST, highlight Change Region, and highlight US8 which includes Tennessee, assuming that’s the area you want. The nav system should then be fully functional.
Perhaps that will correct the time zone problem too, in that the GPS should automatically show the correct local time, other than changing from daylight saving to standard, which you already know how to do.
I would also suggest that you purchase a navigation system owner’s manual as there are many more settings that you may need to make with this as a resource.
Old Apr 21, 2010 | 12:42 PM
hispeed-lowdrag's Avatar
hispeed-lowdrag
Settings -> Change Region
Just click on the map of the USA when you push settings and then change what area you are in and it will be fixed.
It's on pg 4-3 of the Navi manual, here's the online version http://www.infiniti-techinfo.com/ref...-06IT-Navi.pdf
Old Apr 21, 2010 | 03:13 PM
08Gsmith25's Avatar
08Gsmith25
thanks..i have the navi manual. that seems really simple...i know i have been in settings plenty of times, but dont remember "change region." i will try it out in a couple hours after work...thanks again
Old Apr 21, 2010 | 03:56 PM
Chekov's Avatar
Chekov
Senior Citizen
That’s because it’s not in Settings, at least not on a ’08. Change Region is in DEST like I said. But it is on page 4-3 as stated before.
Old Apr 21, 2010 | 03:59 PM
08Gsmith25's Avatar
08Gsmith25
you are right. it worked...
and i was obviously referring to hispeeds post when i said settings
Old Apr 21, 2010 | 04:07 PM
hispeed-lowdrag
yeah I was wrong, its in Destination, not Settings...either way it's in the manual and easy to answer when you read through it
Old Apr 21, 2010 | 04:18 PM
08Gsmith25's Avatar
08Gsmith25
come on...there has to be something said for guy code....
Old Apr 21, 2010 | 10:01 PM
SM_Shadowman's Avatar
SM_Shadowman
Okay, okay, so we won't tell your wife about it then!
OneSickBlackG
Jan 6, 2016 08:49 AM
Falker11
Sep 9, 2015 08:53 PM
Detailed Image
Lighting/Cleaning Products
Sep 8, 2015 02:39 PM
pauliewalnutzz
Sep 8, 2015 11:41 AM
allen738
Sep 6, 2015 09:36 PM
