Droid and G37S
Old 01-20-2010, 02:22 PM
pyctici
pyctici's Avatar
Yeah check radio shack they sell the cables u need to use the headphone jack as an aux out.
Old 01-21-2010, 04:25 PM
mozy
mozy's Avatar
I use a "BlackBerry Bluetooh Audio Gateway" thing to stream music via Bluetooth (A2DP).
https://www.myg37.com/forums/audio-v...atibility.html
Check my posts in that thread. This doesn't apply to 2010 models as I don't own one.
This worked great for me without resorting to cables.
Old 01-22-2010, 03:14 PM
blindman8858
blindman8858's Avatar
How is the audio quality doing it this way? I would imagine it wont be as clear as plugging in directly.
Old 01-22-2010, 03:41 PM
mozy
mozy's Avatar
Quality is just fine. I use it to listen to ShoutCast streams (DroidLive) at 128Kbps. Sound is in stereo. A2DP works really good.
I'm not a "musical snob" so maybe I don't have the ears for it but there is no hissing/noise/etc. Sounds just like my old MP3 player that was plugged into the RCA jacks before, meaning it sounds fine.
I actually wasn't expecting it to sound this good.
Old 01-22-2010, 03:49 PM
blindman8858
wow cool I might try this out
Old 01-31-2010, 04:43 PM
trisailor
trisailor's Avatar
Droid and 2008 G37 - No bluetooth connection
My 2008 G37 will NOT connect with my Motorola Droid phone. Pairing is successful, confirmed by both devices. But they will not connect.
Old 01-31-2010, 06:34 PM
WhosUrBuddiee
WhosUrBuddiee's Avatar
Mine connected just fine
Old 02-01-2010, 02:57 PM
pyctici
pyctici's Avatar
Delete all the profiles currently on the 37 and do the same for the droid. then do a full reset, meaning batt pull. then turn the BT on the drioid on, and use the 37 to search. it will find it and go the the normal pairing....you should be ok that point...if you still having issue connecting, chk the BT connection on the droid with a reg BT headset. It may be the phone BT or it may be the 37 BT....but its easier to find out if its the droid.
Old 02-01-2010, 06:59 PM
ObsidianGT
ObsidianGT's Avatar
Allow me to chime in here. For the 2008 and 2009 owners with AUX input, simply connect the Droid to the car's AUX input:
- With a 3.5mm Stero to RCA audio cable. It's 76 cents, plus postage, can't beat that.
- You can get a little fancier with perhaps a 3.5mm Stereo female to RCA audio male adapter, plus retractable 3.5mm Stereo cable.
- Or if you're going to tuck it away in the center stack and want one cord of just enough length to plug in and tuck away, try this 3.5mm Stereo to RCA audio 1.5ft cable.
The method that Mozy mentioned in this post is great for streaming audio via Bluetooth A2DP into the G's AUX input. For a more streamlined solution, I would suggest the Kensington LiquidAUX Bluetooth Car Kit over Mozy's suggestion. Simply use the A2DP profile only (not headset/handsfree, leave the profile for the car's use).
rbgrant
Buying & Leasing
11-12-2020 11:53 AM
G37 IPL Bryan
09-15-2015 04:40 PM
ThebigJ
08-25-2015 09:22 PM
Zach Stewart
08-18-2015 05:01 PM
Quick Reply: Droid and G37S
