Ip Audio Build
Just a quick question, was the mounting piece of metal for the spare tire sawed off? Cause the amps are sitting right on top of where that piece of metal should be sticking out of.
Nice sit up.
Nice sit up.
I am 99.9% sure this is the way I am going. I wanted to use my 2 12w3's, but there was no way. I used one and made a rack and was planning a floor above, but the room is eaten up. Even with only a 1 cu ft box.
I only differ in that I want to use 2 Dynaudio MW 190's in an IB setup, but we are not sure about the fit on the baffle board. Have to definitively measure it out and make sure before I order and drop the coin. If not, ID was going to be my next choice, although I have heard they are not like they use to be in the good old days.
How do those two subs behave with such a small trunk enclosure colume? i don't know what the Fs is of those, but this is also a concern with the 190's. The fact that I have 2 Zapco 650's at 32+ in does not help either! lol
Might be calling you for some feedback on your amp rack layout.
give me a call if you want your done
thanks
Lou
(323)881-0882
amplifiedmotorsport.com
I beg to differ on the IDQ V3 is as good or better than the old ID'S. are you talking about the DC REF. 650? or the REF 650? This was a customers car but i used 2 DC REF AMPS 750.2 and 1000.4 on mine, basically identical setup as the pictures above. I had to cut a portion of the plasctic pc on the passenger side to make them fit.
Never heard the IDQ's V3 so I can't comment, but I might have to try and find an IB setup with them. Hopefully I will be able to fit the 190's in because the 182's kick some serious midbass azz!
Actually it is one AG650 I had and a Ref 650. I took out those plastic pieces and will be creating a whole new floor. Also have a DSP6 and will have an SLB-U since I prefer to keep gains as low as possible so, I want as much voltage as possible.
I'm trying to get some morel ultimo to test on TB/IB to test
Will you do similar installs w/ other subs that are not part of your "Authorized Dealer" selection?
I am really interested in this set up, but I am not too familiar with those speaker brands that you guys carry.
Would you guys do install and just charge for labor if the items were provided?
Thanks in advance.
Thanks in advance.
Thanks in advance.
Thanks in advance.
delfinparis
Oct 8, 2015 06:06 PM
