Cant find a Remote Tap for adding an amp!
Old Mar 2, 2008 | 06:31 PM
MaxToTheG37's Avatar
MaxToTheG37
Super Moderator w/ Boost
Need help...
I have tried the Grey wire as the Amp diagram posted and I have tried the White wire and its not working...
All that works is the yellow battery wire... I need something that will turn the amp on and off....
Helpppp...
Old Mar 2, 2008 | 07:03 PM
Dieseldoug22's Avatar
Dieseldoug22
I took the signal just before the woofer amp (less cluttered than the full amp) and used the wire that is in the #3 slot. I don't remember if it was green or gray, but just try and use the diagram and look at the connector. It does work, just double check the wire position.
Old Mar 2, 2008 | 07:59 PM
MaxToTheG37
I did that.... It was grey... the number 3 was grey... It was in the white harness going into the small top amp... NO WORK... I dont have a clue why?
I also tried the RCA cable way... soldering onto 8 and 9 on the white connector into the small amp and It worked till I turned up the volume a little and then it was like the small bose amp cut out into protection mode....
I am soo confused...
Old Mar 2, 2008 | 08:16 PM
Dieseldoug22
What amp are you installing?
Old Mar 2, 2008 | 08:23 PM
MaxToTheG37
Rockford T1500bd
Old Mar 2, 2008 | 08:39 PM
Dieseldoug22
Does everything work again after you disconnect it? And the RCA's that you soldered onto the wires are not grounding out?
I can't think of any other reason that it is not working. As long as no wires are touching each other (as I am sure you don't have any), and the inputs and outputs are correct and unless there is an issue with the new amp. I can't see why it wouldn't work. When I installed mine I didn't have any issues so I can't tell what problems there are.
Maybe dillyyo can take a crack at this.
Has anybody else installed an amp yet and could shed some light?
Old Mar 2, 2008 | 08:40 PM
Dieseldoug22
Nice Amp by the way.
Old Mar 2, 2008 | 08:45 PM
MaxToTheG37
Everything worked when i used a hi lo convertr off the rear deck speakers... and when I put the remote wire against my power wire it sounded GREAT!...
I just cant figure a way to find a remote turn on that works...
I used the Grey number 3 like eveyone said they used and the amp would not turn on at all....
Old Mar 2, 2008 | 08:50 PM
Dieseldoug22
Do you have a multi-meter or a 12 volt light meter? If you do double check that there is a voltage running thru the trigger wires when you turn it on. If you don't have a meter you can use a 12v light bulb. If you do have a power going thru the wire to the Bose sub amp than maybe the wire you are using for the trigger is broken.
Old Mar 2, 2008 | 08:56 PM
MaxToTheG37
I had the 12 volt meter and when i touched the grey number 3 and grounded the other needle it glowed red...? but it still would not turn on my AMP... now when i put the remote wire up to the yellow wire that is the 24/7 hot wire it came on....
Old Mar 2, 2008 | 09:03 PM
bboysteele's Avatar
bboysteele
When you turn off the car, there is not power coming from that wire right? #3 wire.
Old Mar 2, 2008 | 09:07 PM
Dieseldoug22
Thats correct. This is actually because the stereo is turned off. That is what controls that wire.
I am baffled as to that configuration MAX. Just see if you can probe around and find a wire that is controlled by the stereo. Like some other trigger wire.
Old Mar 2, 2008 | 09:09 PM
MaxToTheG37
I spent about 3 hrs lookin for a remote tap ...
The grey wire is suppost to only power up when the car is on...
Well its powering up to turn bose amp on but it want turn my RF amp on!! Im am sooo frustrated!
Old Mar 2, 2008 | 09:11 PM
MaxToTheG37
Let me ask this... maybe I was hittin it at the wrong spot...
I tapped into the grey wire about 2 inches before the white harness that went into the smaller top bose amp
Old Mar 2, 2008 | 09:19 PM
Dieseldoug22
It should work wherever you put it. Are you using one of the Scotch locks? The clamping type of connector?
