Cant find a Remote Tap for adding an amp!
Old Mar 4, 2008 | 12:10 AM
  #31
Well I have always heard that your system is as good as its smallest wire... I have 0 grounded already... I just need a way to evening turn the 0 into 4 without being to ghetto....
i need to find a Stinger Distribution block that goes from 0 to )2( 4gauges... I cant seem to find one... any links?
YOu can buy an adapter that goes onto the end of your 0 AWG power wire to reduce it to 4 AWG. Tsunami makes one. I found this one on ebay but I'm sure your local shop could get one.
http://cgi.ebay.com/Tsunami-RA704-Re...QQcmdZViewItem
Another option is to just trim the end of the 0 down to 4 so that it fits. Use a wire stripper for 4 AWG wire and it will cut the strands down to about the right size to fit in the amp.
Old Mar 4, 2008 | 12:13 AM
  #32
MaxToTheG37's Avatar
MaxToTheG37
Super Moderator w/ Boost
sweet
Old Oct 1, 2008 | 12:55 AM
  #33
BayG37's Avatar
BayG37
Hey Max,
How did you end up getting the Remote Wire to work properly?
I'm having the exact same issue with the Gray BOSE remote wire...
Old Oct 1, 2008 | 08:46 AM
  #34
MaxToTheG37
Some amps need a full 12v signal to cut on... the one on the bose is a couple volts lower than 12v so some amps wont cut on with it... some will....
Old Oct 1, 2008 | 11:19 AM
  #35
STOOF's Avatar
STOOF
Just run your remote wire to a switched fuse in the fuse box. THats what i always do.
photocat
Sep 14, 2015 02:32 PM
SuicidalG37SGuy
Sep 10, 2015 06:01 AM
allen738
Sep 6, 2015 09:36 PM
m3clubracer
Sep 1, 2015 09:36 PM
