Where to draw the signal from for the sub?
Old Jun 15, 2010 | 09:56 PM
  #256
hechen507's Avatar
hechen507
I have one more problem when I went thru the manual. There is a control **** called input sensitivity control and it says "set this according to the pre-output level of the center unit connected with this unit.
For the pre-output level, refer to the <specifications> in the instruction manual for the center unit."
It range from min of 5 to max of 0.2. Do you have any idea what this setting should be set to for our G37?
Old Jun 15, 2010 | 11:15 PM
  #257
JLai's Avatar
JLai
Originally Posted by Haji
Oh yeah I remember your problem!
Yeah man any amp is affected by heat, because like I said before you lose current because of heat!
Yep. Gonna re-do the gain this weekend and see if it fixes it. I'll let you know what happens. Thanks again for the help.
Old Jun 16, 2010 | 01:33 PM
  #258
Haji's Avatar
Haji
That'd be called setting the gain.
Setting Amplifier Gain Control - SMD Forum
You will need a DMM, but this is the safest way to prevent clipping.
</specifications>
Old Jun 18, 2010 | 02:45 AM
  #259
hechen507's Avatar
hechen507
</SPECIFICATIONS>
How do I figure this out the voltage chart?
I'm using a 1000 watt RMS and 3500 watts peak subwoofer with dual voice coil @ 4ohm (PIONEER TS-W3002D4). The amp i'm using is 800 watt rms at 4 ohm (Kenwood x1200m).
Also do you think my g37 can handle this? I'm planning to upgrade my grounding wire to 4 gauge.
Old Jun 22, 2010 | 10:29 AM
  #260
Haji's Avatar
Haji
Its the square root of the wattage times impedance.
For example, 1600 @ 1 ohm = 40V AC
Old Jun 22, 2010 | 11:58 AM
  #261
CougarRed's Avatar
CougarRed
Don't buy a powered subwoofer. Do it right man, amp, woofer and enclosure.
At my own peril, I have disregarded the advice of the master. RockFos Punch Overload with remote control on its way. Will be installed by the middle of next week, tapping into lines 33-36.
Old Jun 23, 2010 | 09:09 AM
  #262
tfratzke's Avatar
tfratzke
For you guys with sedans. What side did you run your power lead from? Driver or passenger side of the firewall? Also, what did you use for a ground in the trunk?
Thanks!
Old Jun 24, 2010 | 07:23 PM
  #263
hechen507's Avatar
hechen507
Thanks!
I ran it thru the passenger side. I put the grounding wire in my trunk frame.
Old Jun 24, 2010 | 11:01 PM
  #264
tfratzke's Avatar
tfratzke
Thanks. I was eventually able to find another post with some photos and it seems passenger side is the favorite.
Old Oct 8, 2010 | 09:09 AM
  #265
37Gs's Avatar
37Gs
Does anyone know what the factory bose sub is rated in terms of ohms in the sedan, if it matters the 2010 sedan? w/o nav but doubt that maters.
Even go as far to ask if anyonw knows the output watt rating on the amp for the factory SUB, guess I could do the work and (amps x volts) to get that answer but ohm rating with a volt meter has never worked for ME.
While I am asking the front tweets as well (ohm rating only?)
I simply want to try out replacing the factory sub (with a ported design) and play with enclosure design to get the TONE I want... and perhaps the tweets to get the sound quality I like. Funny thing is I have a high quality amp, 1/3 oct eq and several subs and sizes laying around in the basement... but just want to see for now what a sub swap will do for me to clean up the lowend. Thanks!
Old Oct 10, 2010 | 01:22 PM
  #266
rel230's Avatar
rel230
how would i go about adding a 4 channel amp to my g37.. what wires will i have to splice into in order to get rca signals to my 4channel amp?
Old Oct 13, 2010 | 09:10 PM
  #267
37Gs's Avatar
37Gs
anyone bose sub watts, factory sub ohms, maybe even the factory tweet ohms?
Old Dec 29, 2011 | 09:47 PM
  #268
RoseyPSU's Avatar
RoseyPSU
So I went through this whole post and I was all ready to go. Routed the power cable down the right side no problems. But when I got to the part where I tap in to wires 23-26, I ran in to a dumb problem ... I can't find the Bose amp.
EDIT: For you sedan guys, the Bose amps are mounted under the rear deck on the left side. Picture of the connectors below. The one you want to tap in to is on the right (that you can clearly see the wires). Hope this helps.
Old Jul 30, 2013 | 02:14 AM
  #269
SL651210's Avatar
SL651210
Quick question, other then reviving an old thread, if I were to tap into the wires before the bose for a 4 channel amp, would I tap into #33,34,35,36 and convert the other end into rcas into the amp? If I were to wire a 6 channel amp, which additional 2 wires would I tap into?
Diode Dynamics
Lighting/Cleaning Products
81
Nov 30, 2021 02:28 PM
timc00k
Feb 15, 2017 09:15 AM
flyingnimbus
Oct 3, 2015 12:12 AM
drewfinity
Future Models
Sep 15, 2015 12:49 PM
TVPostSound
General Tech Questions
Sep 2, 2015 04:09 PM
