Question about reverse cam function.
Old Jan 20, 2008 | 11:01 PM
vINCe_Inc's Avatar
vINCe_Inc
So i was thinkin':
The jap spec skyline comes with a side view camera so you can see the passenger side wheel.
what if someone is adventerous enough to discretely mount a tiny wireless camera right below passenger side view mirror (dont ask me how, was thinking you drill a small hole and power it with the same power that powers the motor for for the side view mirror adjusment). and have it transmit wireless signals to one of those wireless receivers that plug directly to the aux / video in.
The question is would the aux / video inn activate when your gear is put to reverse ? i understand the stock reverse camera will come on, but will it be over-ridden by a device plugged in into the aux ?
if it is possible, i might actually be daring enough to try.
Old Jan 20, 2008 | 11:05 PM
DiamondGCoupe's Avatar
DiamondGCoupe
There's probably a way you can just 'plug-in' a sideview mirror with the camera and it 'should' work just fine.. Someone says they found out our units have the software ability for this function to work.
Unfortunately, if the car is moving ie. in reverse, the Aux/Video function will cease to work.
Old Feb 11, 2008 | 04:18 PM
KPierson's Avatar
KPierson
KPtechnologies makes a reverse mirror tilt module that will automatically tilt the passenger mirror when the car is in reverse. Not quite as cool as a video camera but, for the most part, serves the same purpose.
Old Feb 12, 2008 | 02:12 AM
UNV-IT46's Avatar
UNV-IT46
yes i found out the firmware is already in our system for the side camera. It says it in the camera check section. But is there already hook ups for the camera? no idea. Also on the Nissan version the camera is on the passanger side which would be our driver side....
claudiohv
Sep 17, 2015 01:43 AM
rgonz
Sep 11, 2015 04:07 PM
Detailed Image
Lighting/Cleaning Products
Sep 11, 2015 08:33 AM
