Hard Drive Mod
Found this nifty tool - no download needed:
https://www.toolsley.com/inspect.html
ITM HDD1:
/X1E/APP/APP.BIN - navigation images - lots of em
/X1E/CNFTBL/* - no luck. Small files. Guessing some sort of configs
/X1E/DSP/DSP.BIN - nope
/X1E/LANG/* - none
/X1E/SKIN/IMAGE/COLOR0/CLUSTER1.RCL - 5129 images - parking sensors, tires, abs, cruise, basic map outlines?, sprites, diagnostic images, virtual buttons and gauges, more gps errows (different color from APP.BIN), other gps imagery,
../../../COLOR[1-5]/* - almost the same number of images, few of them are different colors - guessing these are just variations of when you pick display color for your HU
/X1E/SKIN/SPLASH/
../TYPE0/* - Infiniti
../TYPE1/* - Nissan
../TYPE2/* - GTR
../TYPE3/* - Nissan (same/similar to 1)
../TYPE4/* - Infiniti (same/similar to 0)
../TYPE5/* - Nissan (similar to 1 and 3)
../TYPE6/* - GTR
../TYPE7/* - Nissan (similar to others)
../TYPE8/* - Inifiniti (similar to others)
../TYPE9/* - Nissan (similar to others)
../TYPE10/* - GTR
../TYPE11/* - Nissan (similar to others)
That's it for now.
ITM HDD1:
/X1E/LANG/* - none
/X1E/SKIN/SPLASH/
../TYPE1/* - Nissan
../TYPE2/* - GTR
../TYPE6/* - GTR
../TYPE10/* - GTR
That's it for now.
lol so replacing folders:
TYPE2 < - > TYPE0
TYPE6 < - > TYPE4
TYPE11 < - > TYPE8
will change the startup logo from Infiniti to GTR
But that will be soooo ricey
The ideea is to edit the app binary so we can get some extra features on stock AV unit.
Like the TPMS pressure display or some parameters display just like on GTR.
That might be possible since the unit already have a CAN communication.
TYPE2 < - > TYPE0
TYPE6 < - > TYPE4
TYPE11 < - > TYPE8
Elco,
Should we start a new 'discovery' thread where we'll break down what each partition / folder is for, what files are in there, and what these files have in them? I'll continue poking around and will open what I can, but it'll definitely have to be a community effort - just need a few more IT guys on this.
TYPE2 < - > TYPE0
TYPE6 < - > TYPE4
TYPE11 < - > TYPE8
TYPE2 < - > TYPE0
TYPE6 < - > TYPE4
TYPE11 < - > TYPE8
I checked the data on hdd. Luck's like the OS core is stored on unit flash memory. The HDD hold's the user interface, voice recognition system, Navigation data and some user data: Bluetooth data, call logs, music, etc...
Something as simple as the startup splash, nav images, color changes, etc - should not be a big deal. Actual functionality like tpms - yea, that will require some serious tinkering and won't be possible unless we figure out how to unlock every file on the disk.
So we don't even care if the OS core is stored on the unit flash memory, as long we can make the OS to run our custom apps.
The problem is compiling that apps...
As we don't know exactly the OS details and what kind of apps it can run. Will be nice if can run linux compiled apps. That will be too easy
Once we can get a custom app to run on the OS, we can make an app that will use any parameter transmited over CAN.
Still.. this will require extensive work.
The main problem is that we have to disassemble the dash to get the AV unit out (not that hard).
Then disassemble the AV unit to get the HDD out. That's not so easy and consume lot of time).
At least 20 minutes needed to get the HDD out of the AV unit.
Copy the file on HDD then assemble the AV unit back (again 20 minutes), and so on...
All this operations make the modding very laborious.
There is not enough space on the unit to add a HDD extension cable.
BTW!!! according to tracking information, the US AV unit will be here in 1-2 days. So prepare for the US HDD image
Hello to all and thank you for your continued work on this project. I'm really excited to see what possibilities may come. Personally I'd love to access the TPMS and the GT-R custom gauge "driver information" displays.
That said, the current TPMS system in the G will not give individual tire readings as most other models do. Different wheel transmitters, and receivers (1 pair for each wheel) as well as a control module will be needed.
As for the driver information/custom gauges functions, The AV system uses the same sensors as is in the G except the G doesnt have turbo and, maybe, the "G" (gravity) sensor unless the yaw rate and the gravity sensor are the same?
Now if the software is already in the AV unit, that's half the battle. Ironically, the pin outs for a 2014 GT-R are 99% identical to the 2014 Q60 (which I just swapped into my '08) only difference being Bose system wiring. I'm even considering doing another swap for the GT-R system!
Im not trying to hijack the thread, i just wanted to share my own thoughts and research. I just wish I was more computer literate! Thanks again to you all!
Some information I was able to get from the disk Volume 1, X1E, APP.BIN. Need help decoding all of this. Some of the information is easy like MGR_BT looks like Manager BlueTooth based on the data.
MNU_AC_GetInnerPartsFocus
E %s : Invalid ItemID
HMI_Ac_AirPurifier_setItem E %s : Invalid Menu
CAMERA /CAMERA_TX1 Camera Mgr device Configure Error
/CAMERA_RX1 compStrgbLwsoutData Size Error(START) %d
compStrgbLwsoutData Angle Error(END) 0x%02x%02x
compStrgbLwsoutData Size Error(END) %d
STRGSenst_MsgWrite IGN-OFF Error
STRGSenst_MsgWrite msg_kind Error %d
STRGSens_MsgWrite Write Error %d
STRGsendReport OSM_MsgSend ERROR !!(0x%x, 0x%x)
STRGsendReport GO GO GO 0x%x 0x%x
STRGSensSendMsgTimeOut Retry(START) %d
STRGSensSendMsgTimeOut StpRetry(END) %d
STRGSensSendMsgTimeOut LwsRetry %d
STRGSensSendMsgTimeOut Retry(END) %d
PMGR_Camera_CenterPNTStart IGN-OFF Error
PMGR_Camera_CenterPNTStart 0x002 Error
PMGR_Camera_CenterPNTStart 0x7c0 Error
PMGR_Camera_CenterPNTStart Status Error %d
SYS_CNF_ITM_ANTICIPATORYLINE Get Error
PMGR_Camera_CenterPNTStart Not AVM
AVM Unit-ID NG !
AVM Unit-ID OK !
OBJ_UnitStsTbl_readUnitID Status Error
AVM Unit-ID NG !!
AVM Unit-ID OK !!
OBJ_UnitStsTbl_readUnitSts Unitsts Error
OBJ_UnitStsTbl_readUnitSts Status Error
OBJ_UnitStsTbl_getObjID Status Error
PMGR_Camera_CenterPNTStart 0x002 Receive Error
PMGR_Camera_CenterPNTStart GO GO GO
PMGR_Camera_CenterPNTStatusRQ IGN-OFF Error
PMGR_Camera_CenterPNTStatusRQ PMGR_CAMERA_CENTERSTOP
PMGR_Camera_CenterPNTStatusRQ PMGR_CAMERA_CENTEREXEC
PMGR_Camera_CenterPNTStatusRQ Status Error(0x%x)
PMGR_Camera_CenterPNTStop Status Error(0x%x)
Information
PMGR_CAMERA_DEV
FdValue1 = 0x%x
FdValue2 = 0x%x
SSSTimeId = 0x%x
Configflg = 0x%x
pmgr_camera_cpntstatus
status = 0x%x
startmsg_cnt = 0x%x
endmsg_cnt = 0x%x
disc_flg = 0x%x
retry_cnt = 0x%x
stpretry_cnt = 0x%x
lwsretry_cnt = 0x%x
lwscal_flg = 0x%x
debug flag ON
debug flag OFF
PMGR_Camera_CenterPNTStart Start
PMGR_Camera_CenterPNTStart Return = 0x%x
PMGR_Camera_CenterPNTStatusRQ Start
PMGR_Camera_CenterPNTStatusRQ Return = 0x%x
PMGR_Camera_CenterPNTStop Start
PMGR_Camera_CenterPNTStop Return = 0x%x
AVM Not-Configration
AVM Unit-ID 0x%02x Write
| 0 : Help
| 1 : Information
| 2 : debug flag ON
| 3 : debug flag OFF
| 4 : Function Call(PMGR_Camera_CenterPNTStart)
| 5 : Function Call(PMGR_Camera_CenterPNTStatusRQ)
| 6 : Function Call(PMGR_Camera_CenterPNTStop)
| 7 : Function Call(PMGR_Camera_CenterPNTStart-2)
| 8 : Function Call(PMGR_Camera_CenterPNTStatusRQ-2)
| 9 : Function Call(PMGR_Camera_CenterPNTStop-2)
| 10 : AVM Control Conection Set(arg1:Not-Conect=0/Conect!=0 arg2:Unit-ID)
HIF Debug Log CORE HIF Debug Log CTRL HIF Debug Log MAP HIF Debug Log SYSTEM HIF Debug Log ALL HIF_Debug : Unknown type = %d
HIF_Debug : Unknown debug log type %d
HIF_Debug : index out of range
%s off
%s on
********** ********** HIF_Debug : Add map request stack ********** **********
********** ********** HIF_Debug : Send request map ********** **********
********** ********** HIF_Debug : Show map info status ********** **********
********** ********** HIF_Debug : Clear map info ********** **********
********** ********** HIF_Debug : Add town map request stack ********** **********
HIF_Debug : illegal argument %d !!
===== Map Management Flag(System) =====
HIF Map Management Flag : %d
===== Connect Id =====
HIF Connect Id : %d
===== Now Request Id =====
Request Id : %d
===== Waiting Map List =====
Mesh Id : %x Kind %x
===== Return Map Status =====
********** Management Data[%d] **********
Mesh Id : %x
Guide Data : status = %x record = %x
Road Data : status = %x record = %x
===== Return Town Map Status =====
********** Town Data **********
Town Data : status = %x record = %x
===== Clear Request Id =====
===== Clear Waiting Map List =====
===== Clear Map Management Info =====
Invalid Mesh Id %x
No useful divide %x
[2] | [3]
[0] | [1]
HIF_Debug : HIF_DebugStackMap failed
HIF_Debug : invalid mesh x, y
HIF_Debug : HIF_DebugStackTownMap failed
HIF_OWN_COND_VOID HIF_OWN_COND_INIT HIF_OWN_COND_RESET HIF_OWN_COND_MOVE HIF_OWN_COND_FIRST_MATCH HIF_OWN_COND_APPROACH HIF_OWN_COND_THROUGH HIF_OWN_COND_FREE_OVER Äɽ ØÉ½ ìɽ ʽ ʽ 0ʽ Hʽ `ʽ HIF_OWN_WPAREA_VOID HIF_OWN_WPAREA_ESCAPE ˜Ê½ ¬Ê½ OBJ_CARPOSMATCHSTATUS_INIT OBJ_CARPOSMATCHSTATUS_MATCH OBJ_CARPOSMATCHSTATUS_FREE OBJ_CARPOSMATCHSTATUS_TURN OBJ_CARPOSMATCHSTATUS_ONROUTE OBJ_CARPOSMATCHSTATUS_DEVROUTE OBJ_CARPOSMATCHSTATUS_ONHIGHWAY OBJ_CARPOSMATCHSTATUS_OFFHIGHWAY OBJ_CARPOSMATCHSTATUS_RESETFREE OBJ_CARPOSMATCHSTATUS_DELIBER OBJ_CARPOSMATCHSTATUS_OFFROUTE OBJ_CARPOSMATCHSTATUS_INSAPA OBJ_CARPOSMATCHSTATUS_OUTSAPA Ìʽ èʽ ˽ ˽ data[0] != MAL_SUCCESS(%d)
********** HIF_MapEvtCtl
receive Map Data req No = %d, last req No = %d
HIF_MapEvCtrl : illegal req no %d (%d)
HIF_MapEvtCtl : HIF_MapEvtProc get illegal message!!
@HIF : MAL_Connect ERR!!
HIF_MapEvtCtl : map data release failed on debug command!!
HIF_MapLib : illegal divide %x %d
HIF_MapLib : get mesh failed. %x, %d
HIF_MapLib : request buffer over!!
HIF_MapLib : STD_MeshPnt
HIF_MapLib : STD_PntData_setMeshPnt failed
HIF_MapLib : invalid STD_PntData
HIF_MapLib : request town data is over!!
HIF_MapLib_getAreaName: MAL_AREACLS1CSH_GetObj AREACLASS1 Get
HIF_MapLib_getAreaName: MAL_AREACLS2CSH_GetObj AREACLASS2 Get
HIF_MapLib_getAreaName: MAL_AREACLS3CSH_GetObj AREACLASS3 Get
HIF_MapLib_getAreaName: MAL_AREACLS4CSH_GetObj AREACLASS4 Get
HIF_MapLib_getAreaName: MAL_AREACLS_ReqData AREACLASS1 Get
HIF_MapLib_getAreaName: MAL_AREACLS_ReqData AREACLASS2 Get
HIF_MapLib_getAreaName: MAL_AREACLS_ReqData AREACLASS3 Get
HIF_MapLib_getAreaName: MAL_AREACLS_ReqData AREACLASS4 Get
HIF_MapLib_getAreaName: MAL_AREACLS_ReqData AREACLASS5 Get
@HIF_task: MAL_AREACLS_ReleaseData ERROR!!
HIF_OwnPos_initOwnPosInfo : Init area event failed
HIF : HIF_Init HIF_MapEvt_regMapEvent failed
HIF_TaskMain : OSM_TaskReceive(WAIT_FOREVER) is failure!!! HIF_task : SYSTEM RUN -> STOP
HIF_TaskMain : get HIF_OBJEVTYPE_MAPINFO and HIF_MapEvt_releaseMapDataAll failed
HIF_TaskMain : HIF_TaskMain_runStopProc returns ERROR
HIF_TaskMain : received event type %d
HIF : f_HIF_task HIF_MapEvt_reqData is failed
HIF_TaskMain_SystemEventProc : event != HIF_OBJEVTYPE_MAPINFO
HIF_TaskMain : OBJ_MapInfo Msg(FREE) Received
HIF_Task STOP -> RUN
HIF : HIF_OwnPos_startOwnPosEvent
HIF : OBJ_MapInfo Msg(FREE) Send
HIF : OBJ_MapInfo Msg(BKUPCLR) Received
HIF_task : OBJ_MapInfo_rspnsPublic(BKUPCLR) Error HIF : OBJ_MapInfo Msg(BKUPCLR) Send
HIF : OBJ_MapInfo Msg(BKUPCHG) Received
HIF_task : OBJ_MapInfo_rspnsPublic(BKUPCHG) Error HIF : OBJ_MapInfo Msg(BKUPCHG) Send
HIF : OBJ_MapInfo Msg(APPSTOP) Received
HIF_task : OBJ_MapInfo_rspnsPublic(APPSTOP) Error HIF : OBJ_MapInfo Msg(APPSTOP) Send
HIF : OBJ_MapInfo Msg(APPLIMITED) Received
HIF_task : _rspnsPublic(APPLIMITED) Error HIF : OBJ_MapInfo Msg(APPLIMITED) Send
HIF_TaskMain_SystemEventProc : Not execute event proc!!
HIF_Wai_Dsp_updateDist : nxt dist[%d]
HIF_Wai_Dsp_updateDist : pre dist[%d]
HIF_Wai_Dsp_editCurrentStreet : HIF_Wai_Local_setNameinf
HIF_Wai_Dsp_editNextStreet : START
HIF_Wai_Dsp_editNextStreet : koho Nodata
HIF_Wai_Dsp_editNextStreet : KOHO NUM[%d]
HIF_Wai_Dsp_editNextStreet : DSPK_FRBD
HIF_Wai_Dsp_editNextStreet : DSPK_FRRD
HIF_Wai_Dsp_editNextStreet : EXIST
HIF_Wai_Dsp_editNextStreet : !STD_JUDGE_SAME
HIF_Wai_Dsp_editNextStreet : NODATA
HIF_Wai_Dsp_editNextStreet : STD_JUDGE_SAME
HIF_Wai_Dsp_editPreviousStreet : Start
HIF_Wai_Dsp_editPreviousStreet : KOHO Nodata
HIF_Wai_Dsp_editPreviousStreet : KOHO NUM[%d]
HIF_Wai_Dsp_editPreviousStreet : HIF_WAI_DSPK_BKBD
HIF_Wai_Dsp_editPreviousStreet : HIF_WAI_DSPK_BKRD
HIF_Wai_Dsp_editPreviousStreet : HIF_STS_EXIST
HIF_Wai_Dsp_editPreviousStreet : HIF_STS_NODATA
HIF_Wai_Dsp_editPreviousStreet : STD_JUDGE_SAME
HIF----- OBJ_CarCircumInfo_writeCircum Write OK-----
HIF----- set Next Street -----
HIF----- set Current Street -----
HIF----- set Previous Street -----
HIF----- set Status EXIST -----
HIF----- set Status SEARCH -----
HIF----- set Status NODATA -----
HIF----- set Status UNKNOWN -----
HIF----- set Status ERROR -----
AVM Unit-ID NG !
AVM Unit-ID OK !
AVM Unit-ID NG !!
AVM Unit-ID OK !!
Information
PMGR_CAMERA_DEV
FdValue1 = 0x%x
FdValue2 = 0x%x
SSSTimeId = 0x%x
Configflg = 0x%x
status = 0x%x
startmsg_cnt = 0x%x
endmsg_cnt = 0x%x
disc_flg = 0x%x
retry_cnt = 0x%x
stpretry_cnt = 0x%x
lwsretry_cnt = 0x%x
lwscal_flg = 0x%x
debug flag ON
debug flag OFF
| 0 : Help
| 1 : Information
| 2 : debug flag ON
| 3 : debug flag OFF
%s off
%s on
HIF Connect Id : %d
Request Id : %d
Mesh Id : %x
Invalid Mesh Id %x
No useful divide %x
[2] | [3]
[0] | [1]
HIF: HIF_Wai_Local_setNameinf link_inf ERR
HIF_Wai_Local_setNameinf: CurrentStreet Noreq
HIF_Wai_Local_setNameinf: NextStreet Noreq
HIF_Wai_Local_setNameinf: PreStreet Noreq
HIF_Wai_Local_setAreaNameinf: HIF_MapLib_getAreaName ERROR
HIF-----area_name Get OK-----
HIF : HIF_Wai_Local_setRoadNameinf MAL_LINK_ConvertObj ERR
HIF_Wai_Local_setRoadNameinf: HIF_MapLib_getParcelHdl[%d]
HIF_Wai_Local_setRoadNameinf: MAL_GUIDE_NODE_GetObj[%d] Nodata
HIF_Wai_Local_setRoadNameinf: MAL_GUIDE_NODE_GetObj[%d] Err
HIF-----road_name Get OK----- road_name_cnt[%d]
HIF-----road_num Get OK----- road_num_cnt[%d]
HIF_Wai_Main_ctrl : HIF_EVENT_OWN_RESET
HIF_Wai_Main_ctrl : HIF_EVENT_OWN_CARPOS
HIF_Wai_Main_ctrl : CurrentStreet HIF_STS_NOREQ
HIF_Wai_Main_ctrl : HIF_OWN_COND_MOVE
HIF_Wai_Main_ctrl : CurrentStreet Order
HIF_Wai_Main_ctrl : HIF_OWN_COND_FIRST_MATCH
HIF_Wai_Main_ctrl : HIF_OWN_COND_APPROACH
HIF_Wai_Main_ctrl : HIF_OWN_COND_THROUGH
HIF_Wai_Main_ctrl : HIF_OWN_COND_FREE_OVER
HIF_Wai_Main_ctrl : HIF_EVENT_OWN_SIM
HIF_Wai_Main_ctrl : CurrentStreet Noreq
HIF_Wai_Main_ctrl : HIF_EVENT_OWN_AREA
HIF_Wai_Main_ctrl : MSG_TYPE_HDLMAP_ACK
HIF_Wai_Local_PreviewWhenApproach : JPKIND_TERM JPKIND_LIMIT
HIF_Wai_Local_PreviewWhenApproach : setInLInkInfo Nodata
HIF_Wai_Local_PreviewWhenApproach : Front preview HIF_STS_EXIST
HIF_Wai_Local_PreviewWhenThouugh : JPKIND_TERM
HIF_Wai_Local_PreviewWhenThouugh : JPKIND_LIMIT
HIF_Wai_Local_PreviewWhenThouugh : JPKIND_JOIN
HIF_Wai_Local_PreviewWhenThouugh : HIF_Wai_Local_setInLInkInfo Nodata
HIF_Wai_Local_PreviewWhenThouugh : Front preview HIF_STS_EXIST
HIF_Wai_Local_PreviewWhenThouugh : Back preview HIF_STS_EXIST
HIF_Wai_Trc_previewFront: HIF_WAI_EXE_FIRST
HIF_Wai_Trc_previewFront: HIF_WAI_EXE_CONT
HIF_Wai_Trc_previewFront: trace_length > HIF_WAI_LIM_DIST_FR(50000)
HIF_Wai_Trc_previewFront: HIF_Wai_Local_previewRunFront HIF_STS_EXIST
HIF_Wai_Trc_previewFront: HIF_Wai_Local_previewRunFront HIF_STS_ON_ORDER
HIF_Wai_Trc_previewFront: HIF_Wai_Local_previewRunFront HIF_STS_WITHOUT
HIF_Wai_Trc_previewFront: HIF_Wai_Local_previewRunFront LOCAL_ESTS_END
HIF_Wai_Trc_previewFront: LOCAL_ESTS_JOIN_ST
HIF_Wai_Trc_previewFront: HIF_Wai_Local_setFrontFirstKoho HIF_STS_EXIST
HIF_Wai_Trc_previewFront: HIF_Wai_Local_setFrontFirstKoho HIF_STS_NODATA
HIF_Wai_Trc_previewFront: LOCAL_ESTS_JOIN_CNT
HIF_Wai_Trc_previewFront: HIF_Wai_Local_previewJoinFront HIF_STS_ON_ORDER
HIF_Wai_Trc_previewFront: koho EXIST
HIF: HIF_Wai_Local_setInLInkInfo MAL_LINK_CnvLinkIDtoLINK ERR
HIF_Wai_Trc_previewBack : HIF_WAI_EXE_FIRST
HIF_Wai_Trc_previewBack : HIF_WAI_EXE_CONT
HIF_Wai_Trc_previewBack : trace_length>HIF_WAI_LIM_DIST_BR(50000)
HIF_Wai_Trc_previewBack : HIF_Wai_Local_previewRunBack HIF_STS_EXIST
HIF_Wai_Trc_previewBack : HIF_Wai_Local_previewRunBack HIF_STS_ON_ORDER
HIF_Wai_Trc_previewBack : HIF_Wai_Local_previewRunBack LOCAL_ESTS_END
HIF_Wai_Trc_previewBack : HIF_Wai_Local_setBackFirstKoho HIF_STS_EXIST
HIF_Wai_Trc_previewBack : HIF_Wai_Local_setBackFirstKoho HIF_STS_NODATA
HIF_Wai_Trc_previewBack : HIF_Wai_Local_previewJoinBack HIF_STS_ON_ORDER
HIF_Wai_Trc_previewBack : koho EXIST
HIF: HIF_Wai_getOutLink MAL_LINK_CnvLinkIDtoLINK ERR
HIF: HIF_Wai_getOutLink MAL_LINK_ConvertObj ERR
HIF: Local_getNextLinkNodeInMesh MAL_LINK_GetConnectLINK ERR
HIF_Wai_Local_getAdjoiningMeshLinkNode: MAL_LINK_GetNextConnectLinkObj ERR
HIF_Wai_Local_getAdjoiningMeshLinkNode: MAL_LINK_GetNextConnectLink ERR
HIF_Wai_getLinkInfo : MAL_LINK_ConvertObj Err
HIF_Wai_getLinkInfo : MAL_LINK_GetParcelID Err
HIF_Wai_getLinkInfo : MAL_LINK_GetRoadNameNum Err
AT+BLSV l ¾ AT+BSLV x ¾ AT+BPIN „ ¾ AT+BSPM ¾ AT+BCRO œ ¾ AT+BPRM ¨ ¾ AT+BMST ´ ¾ AT+BSDD À ¾ AT+BHMM Ì ¾ AT+BSEC Ø ¾ AT+BLPS ä ¾ AT+BAFH ð ¾ AT+BNAM ü ¾ AT+BQAL ¾ AT+BSBR ¾ AT+BCOD ¾ OK ,¾ ERROR 4¾ ERROR: @¾ +BINF L¾ +BPIN X¾ +BPRC d¾ +BRSA p¾ +BRNM |¾ +BNAM ˆ¾ +BINQ ”¾ +BINC *¾ +BROL ¬¾ +BLPM ¸¾ +BCRO ľ +BSBR о +BCOD ܾ +BLST è¾ +BHCN ô¾ +BSCO ¾ +BCST ¾ +BCME ¾ +BCAL $¾ +BHOP 0¾ +BRSN nothing to do
password -> userid -> MGR_BT(syncml):mgr_bt_set_auth_param_bda return NOT TRUE.
MGR_BT(syncml): updated bda[%s], pass[%s], id[%s].
--- SYNCML¥Ç¥Ð¥Ã¥¯¥³¥Þ¥ó¥É ---
801 : SYNCMLÆâÉô¥¹¥Æ¡¼¥¿¥¹É½¼¨
802 : Trace levelÊѹ¹
803 : RingBuffer»ÈÍÑLog½ÐÎÏ
804 : RingBuffer»ÈÍÑLog¥¯¥ê¥¢
805 : SYNCMLÆâÉô¾õÂ֥ꥻ¥Ã¥È
806 : ¥ê¥â¡¼¥È¥Ç¥Ð¥¤¥¹¤ËÀܳ¤¹¤ë(Connect)
807 : SYNCMLÀܳ¤òÀÚÃǤ¹¤ë(DisConnect)
808 : ÅÅÏÃÄ¢¤ò¥À¥¦¥ó¥í¡¼¥É¤¹¤ë¡Ê̤ưºî¡Ë
809 : +BRFCÂÔ¤Á¥¿¥¤¥Þ¡¼ÀßÄê
810 : +CIRGÂÔ¤Á¥¿¥¤¥Þ¡¼ÀßÄê
811 : +CALEÂÔ¤Á¥¿¥¤¥Þ¡¼ÀßÄê
812 : +CCINÂÔ¤Á¥¿¥¤¥Þ¡¼ÀßÄê
813 : +CSEIÂÔ¤Á¥¿¥¤¥Þ¡¼ÀßÄê
814 : +CPBGÂÔ¤Á¥¿¥¤¥Þ¡¼ÀßÄê
815 : +CSTAÂÔ¤Á¥¿¥¤¥Þ¡¼ÀßÄê
816 : ¥ê¥â¡¼¥È¥Ç¥Ð¥¤¥¹¤ËÀܳ¤¹¤ë2(Connect)¡ÊBDA»ØÄê²Äǽ¡ Ë(¹©»öÃæ)
817 : SRAM¤Øpassword,id¤òÅÐÏ¿
NOT_INITIALIZED INITIALIZED CONNECT_PROG AUTHENTICATE CONNECTED START_PROG INIT_CL_PROG INIT_SV_PROG SYNCRONIZE SYNC_CHECK_PROG CANCEL_PROG DISCONNECT_PROG MGR_BT(syncml):mgr_bt_syncml_get_status_string failed @1.
MGR_BT(syncml):mgr_bt_syncml_recvBRFC().
MGR_BT(syncml):mgr_bt_syncml_recvBRFC returned @1.
MGR_BT(syncml):mgr_bt_syncml_recvBRFC send event connected .
MGR_BT(syncml):mgr_bt_syncml_recvBRFC send event connect_err .
MGR_BT(syncml):mgr_bt_syncml_recvBRFC send event connect_err(auth_err) .
MGR_BT(syncml):mgr_bt_syncml_recvBRFC syncml status = [%d]
MGR_BT(syncml):mgr_bt_syncml_recvBRFC send event aborted.
MGR_BT(syncml):mgr_bt_syncml_recvBRFC send event disconnected. sts[%02d]
MGR_BT(syncml):Retry count over limit.
MGR_BT(syncml):mgr_bt_syncml_recvCOPW().
MGR_BT(syncml):mgr_bt_syncml_recvCOPW returned @1.
MGR_BT(syncml):mgr_bt_syncml_recvCOPW returned @2 (param1 error).
MYPASSWORD MYUSERID AT+COPW=%s,%s
AT+COPW=%s
MGR_BT(syncml):mgr_bt_syncml_recvCOPW MGR_BT_TxData failed.
MGR_BT(syncml):mgr_bt_syncml_recvCALE().
MGR_BT(syncml):mgr_bt_syncml_recvCALE returned @1.
AT+CCLI
MGR_BT(syncml):mgr_bt_syncml_recvCALE failed @2(MGR_BT_TxData failed).
MGR_BT(syncml):mgr_bt_syncml_recvCCIN().
MGR_BT(syncml):mgr_bt_syncml_recvCCIN returned @1.
AT+CSIN=MY-CAR
MGR_BT(syncml):mgr_bt_syncml_recvCCIN failed @2.
MGR_BT(syncml):mgr_bt_syncml_recvCSEI().
MGR_BT(syncml):mgr_bt_syncml_recvCSEI returned @1.
AT+CGPB
MGR_BT(syncml):mgr_bt_syncml_recvCSEI failed @3.
MGR_BT(syncml):mgr_bt_syncml_recvCSTA().
MGR_BT(syncml):mgr_bt_syncml_recvCSTA returned @1.
MGR_BT(syncml):mgr_bt_syncml_recvCSTA MGR_BT_TxData failed.
MGR_BT(syncml):mgr_bt_syncml_recvCIRG().
MGR_BT(syncml):mgr_bt_syncml_recvCPBE(). [%s]
MGR_BT(syncml):mgr_bt_syncml_recvCPBE returned @1.
MGR_BT(syncml):mgr_bt_syncml_recvCPBG data_len = [%d].
MGR_BT(syncml):mgr_bt_syncml_recvCPBG returned @1.
MGR_BT(syncml):mgr_bt_syncml_recvCPBG returned @2.
AT+CSTR=1
MGR_BT(syncml):mgr_bt_syncml_recvBRFC failed @3.
MGR_BT(syncml):mgr_bt_syncml_recvCPBG failed @4.
MGR_BT(syncml):mgr_bt_syncml_recvCPBG data_len(%d) out of range).
MGR_BT(syncml):mgr_bt_syncml_recvCPBG ~write_data failed.
MGR_BT(syncml):ERROR:%04X received.
MGR_BT(syncml):mgr_bt_syncml_recvERROR error = [0x%04x]
MGR_BT(syncml): ERR_BLOCK_CMD_NOT_COMPLETE -> RESET
MGR_BT(syncml):[ [ [ [ Reset ] ] ] ]
MGR_BT(syncml):MGR_BT_SyncmlSysERR occured.
MGR_BT(syncml):mgr_bt_syncml_ConnectRequest failed @1.
MGR_BT(syncml):mgr_bt_syncml_ConnectRequest failed @2.
AT+CPAU=1
MGR_BT(syncml):mgr_bt_syncml_ConnectRequest failed (AT+CPAU).
AT+BCNL
MGR_BT(syncml):mgr_bt_syncml_ConnectRequest failed (AT+BCNL).
MGR_BT(syncml):mgr_bt_syncml_ConnectRequest ~stringAddress failed.
AT+BMST=F,%s,FF,1,5
MGR_BT(syncml):mgr_bt_syncml_ConnectRequest failed (AT+BMST).
MGR_BT(syncml):mgr_bt_syncml_DisconnectRequest failed @1.
MGR_BT(syncml):mgr_bt_syncml_SyncronizeRequest failed @2.
AT+BDIS=F
MGR_BT(syncml):mgr_bt_syncml_DisconnectRequest failed @3.
MGR_BT(syncml):mgr_bt_syncml_SyncronizeRequest failed @1.
AT+CALE
MGR_BT(syncml):mgr_bt_syncml_SyncronizeRequest failed @3.
MGR_BT(syncml):mgr_bt_syncml_CancelRequest failed @1.
MGR_BT(syncml):mgr_bt_syncml_CancelRequest failed @2.
AT+CIRS
MGR_BT(syncml):mgr_bt_syncml_CancelRequest failed @3.
MGR_BT(syncml):mgr_bt_syncml_ClearTimer failed @1.
MGR_BT(syncml):Timer_(%d) Stop.
MGR_BT(syncml):Timer_(%d) is not setted.
MGR_BT(syncml):mgr_bt_syncml_SetTimer failed @1.
MGR_BT(syncml):Timer_Id(%d) Start(%d).
MGR_BT(syncml):NOT invalid Timer_Id(%d).
BD ADDR -> MGR_BT(syncml):mgr_bt_syncml_ReStartServiceConn failed.
AT+BSLV
MGR_BT(syncml):mgr_bt_syncml_ReStartServiceConn MGR_BT_TxData failed.
MGR_BT(syncml):mgr_bt_syncml_ReStartServiceConn msg @3(connectable off).
MGR_BT(syncml):mgr_bt_syncml_Unsniff ~binary2stringAddress failed
AT+BSPM=%s,0
MGR_BT(syncml):mgr_bt_syncml_Unsniff failed.
MGR_BT(syncml):mgr_bt_syncml_Unsniff OK.
MGR_BT(syncml):mgr_bt_syncml_init_data IOLIB_Ring_Connect failed.
MGR_BT(syncml):mgr_bt_syncml_init_data OSM_SemCreate failed.
MGR_BT(syncml):mgr_bt_syncml_read_data arg failed.
MGR_BT(syncml):mgr_bt_syncml_read_data no data.
MGR_BT(syncml):mgr_bt_syncml_write_data failed @1.
MGR_BT(syncml):¡üMaxRingUsed is updated. %d
MGR_BT(syncml):Ring buffer overflow. Data is discarded.
MGR_BT(syncml):mgr_bt_syncml_write_data IOLIB_Ring_PutBuf failed.
MGR_BT(syncml):mgr_bt_syncml_Lock_local() failed.
MGR_BT(syncml):mgr_bt_syncml_Unlock_local() failed.
MGR_BT(syncml):mgr_bt_syncml_ring_log failed @1.
MGR_BT(syncml)Ring buffer log is not exist.
[ n ] write_size read_size now_used max_used / capacity
AT+COPW=%s
AT+CCLI
AT+CSIN=MY-CAR
AT+CGPB
AT+CSTR=1
AT+CPAU=1
AT+BCNL
AT+BMST=F,%s,FF,1,5
AT+BDIS=F
AT+CALE
AT+CIRS
AT+BSLV
AT+BSPM=%s,0
But if you use Consult 3, you can get INDIVIDUAL TIRE PRESSURE INFORMATION. I tested this and IT WORK'S!!! using Live data monitor function on Consult 3.
So TPMS system DO send the individual tire pressure information over the CAN BUS. The trick is to send the data request to TPMS module and interpret the recieved data.
YES!!! The yaw sensor can measure acceleration
From information earlier in this post and research online it looks like Nissan is using QNX neutrino for the Operating System on the G37 and GTR.
I've download the VMware image to start testing.
http://www.qnx.com/developers/docs/6...t%2Fabout.html
