Hard Drive Mod
Old Mar 30, 2022 | 07:49 AM
  #286
Remapper's Avatar
Remapper
Hello everyone, does anyone have the dump of 370Z with NAV??
I need an unlocked one so I can restore to my dead drive.
Thank you all!
Old Mar 30, 2022 | 09:37 AM
  #287
iCrap's Avatar
iCrap
I dont
I have a 2014 Q60 rip, I don't know if it would work though... maybe? It might just be Infiniti themed but may work.
Old Mar 30, 2022 | 10:03 AM
  #288
ILM-NC G37S's Avatar
ILM-NC G37S
Either that or just buy a used 370Z headunit from eBay and pop that in.
Old Mar 30, 2022 | 11:31 AM
  #289
Remapper's Avatar
Remapper
The photograph of the unit is this, as long as the dump is for this system it works for me.
Important that it has the navigation part.
Old Mar 30, 2022 | 11:36 AM
  #290
iCrap's Avatar
iCrap
Actually I forgot i posted the link before (macrium reflect image)
https://mega.nz/file/kl82WJiC#vCB4bj...f6OiJzKI5HzGkY
It is nav, the HDD models are the only ones with navigation. it should work.... give it a try and let us know. As far as i know the only difference would be the boot screen.
Old Mar 30, 2022 | 11:48 AM
  #291
Remapper's Avatar
Remapper
Thanks. Its unlocked¿?
Old Mar 30, 2022 | 04:05 PM
  #292
AdamBritt's Avatar
AdamBritt
Originally Posted by icecube45
You could always just give up on the stock system :P
Which app are you using?
Old Mar 31, 2022 | 09:56 AM
  #293
iCrap's Avatar
iCrap
Yes its unlocked
That's Open Dash running on a Raspberry Pi.
Old Apr 12, 2022 | 05:25 PM
  #294
ihateu3's Avatar
ihateu3
@iCrap Hello, I just registered here after reading some of this thread. I own a 2010 GT-R USDM spec with nav, and either my HDD died, or my headunit is bad. According to the headunit, I get messages saying the HDD is bad, and sometimes saying that a map update has failed. Being that I am not your average "wealthy" GT-R owner, I am trying everything in my power to repair this problem cheaply.
I tried to read the disk just by hooking it to my windows machine. It spun up and did not click, and it was viewable through device managager, but not viewable through disk management. Any clone software I tried to fire up would hang on scanning disks with the drive plugged in (USB to ide), and if I rebooted my PC with it plugged in, it would hang my BIOS. I did end up sending my HDD away to a HDD repair place, and they stated that it was password-protected, and I thought they said they were able to remove the password (maybe they said unable), but I do know that they said they were unable to see any data, although it appeared that the HDD appeared to be working properly.
I am waiting for the HDD to ship back to me from the HDD recovery place. Is there anything of value that I could possibly help with? I feel that if you guys get the GT-R software working on a G37, then I also could buy the much cheaper G37 headunit and run it in my GT-R if in fact my head unit is dead. If not, then I at least could possibly still benefit from a disk image so that I can replace my HDD.
Old Apr 12, 2022 | 07:15 PM
  #295
iCrap's Avatar
iCrap
Hey, the behavior you mentioned makes perfect sense, as that is what will happen when the drive is still locked, you won't see anything at all. Also - you mentioned that you use an IDE-USB adapter, and that would only really work once the drive has been unlocked. The only way I have been able to unlock the drive is with an old PC on IDE onboard the motherboard.
If you have a legacy PC with IDE I can guide you through unlocking the drive. OR if not, you can ship me the drive and I can try to extract the image from it (assuming it's not actually dead of course)
Old Apr 12, 2022 | 10:22 PM
  #296
ihateu3's Avatar
ihateu3
Ok, I don't have a legacy PC off-hand with IDE support, so I can possibly send it off to you as long as I could get it back in a somewhat reasonable time frame. Would the resulting image from a 2010 GT-R HDD be of any value for what you are trying to do? I thought I read earlier in the thread that you were looking for a 2010 HDD, but I may have read that wrong.
Old Apr 13, 2022 | 12:11 AM
  #297
iCrap's Avatar
iCrap
Yeah, so basically my project came to a standstill since the goal was to unlock the GT-R menus on the G37 headunit - my car has the older head unit (pre 2010) which after digging through my image, it turns out the GT-R stuff is just not there. Its on my list to get my hands on a 2010+ setup and mess around with it more. We also figured out serial access into the headunit, so I can connect up and send it commands / unlock functions etc. (i posted screenshots of that before)
With the GT-R image it would probably help make some progress towards unlocking the GT-R menus on the G37. So if you want, I can try the same unlock, clone the drive, upload the image and send the drive back over. I was able to clone my own drive onto another and it did boot up fine, so should work for your GT-R too. (I did try cloning to SSD but that didn't boot unfortunately, but it could just be that particular SSD)
Old Apr 13, 2022 | 11:34 AM
  #298
ILM-NC G37S
Originally Posted by ihateu3
... I just registered here after reading some of this thread. I own a 2010 GT-R USDM spec with nav, and either my HDD died, or my headunit is bad. According to the headunit, I get messages saying the HDD is bad, and sometimes saying that a map update has failed.
@ihateu3 It seems that the GT-R's are seriously prone to problems with the AV/Infotainment system. As expensive as those cars are it is ridiculous how many problems have been documented.
Have you contacted forum member legertas over at gtrlife.com? He seems to be the definitive "go to" guy regarding the GT-R's AV issues. Granted he will probably try to sell you one of his kits, but never hurts to ask...
Old Apr 13, 2022 | 11:41 AM
  #299
ihateu3's Avatar
ihateu3
Yes, I have been in contact with him and am still in contact with him over this, and he did try to sell me his kit. I may be able to work something out with him to buy just the HDD and the "mainboard", since he stated that the G37 head unit will work and is almost the same, but that the GT-R software is not only just on the HDD. I do believe that his conversion kit is the best option, but I don't really have money like that to throw around and would prefer a cheaper fix if possible. Even if I did have that kind of money, my priority would be to spend it on performance items over the head unit.
Old Apr 13, 2022 | 12:07 PM
  #300
ILM-NC G37S
Legertas helped me w/ a similar question I had once years ago. He means well, and is a great guy who knows his stuff. But, first and foremost he is a businessman.
... the GT-R software is not only just on the HDD.
I disagree here. These headunits were mass produced and as these cars rolled off the factory line, the configurations were written to the system. Folks with these same headunits have been able to unlock the HDD, reconfigure the "setup" and run the GT-R "theme." It is just a matter of being able to write the new configurations. If they can do it on a Murano unit, it can theoretically be done on just about any similar Nissan unit.
I agree, totally.
Good luck.
